Hi, I'd like to watch some of my VHS captures on my plex server, which so far are captured through AmaRec at 25i Lagaryth. If I do a simple recompress to a more manageable 25i mp4 my TV does an ok job at deinterlacing but there's often judder and combing artifacts.
I've also tried yadif 25p and 50p deinterlacing through ffmpeg. My favourite result I think is 50p interpolation as there's no artifacts and gives that 50fps illusion that you get through a CRT tv but it seems a very inefficent way to go about simply playing vhs captures on a modern TV. The files are also much bigger.
So I was wondering what your favourite methods are for playing back VHS captures on a modern TV without artifacts? Thanks!
	Hi,
 couple of things I want to mention:
 1) Put simply, bob-deinterlacing is merely an interpolation on the spatial dimension of video – not time. It turns those 50 fields per second into 50 frames per second by filling the gaps (missing scanlines). Hence the motion of bob-deinterlaced 50p video is not an "illusion", it is indeed proper 50p like from a native 50p source.
 2) Encoding 50p is not particularly inefficient. Assuming you are encoding h264 (such as x264), there is not a big difference in encoding efficiency when encoding 50p versus 25i.
 3) In case of CRF encoding in x264, file sizes probably differ because of the way x264 distributes bitrate/quality in interlaced vs. progressive encoding.
 If you were to tune CRF so that both encodings (25i and 50p) end up with pretty much the same file size, they are going to look both pretty similar in terms of quality (compression artefacts).
 So my advice is: bob-deinterlace to 50p with whatever deinterlacer suits your expectations (or CPU time^^) and encode 50p at the videos native resolution (no upscaling, use SAR).Last edited by Skiller; 6th Jun 2021 at 19:15.
	Now and days I deinterlace with qtgmc on my captures. The motion is always correct and I quit having loss of detail. If it's truly 60 fields the file size reflects that ( I encode with x264 in qp not crf mode). If it's only telecined I noticed a 10% increase in size at the upper end which is worth it to me to not have to worry about the motion and detail per capture. if all else fails read the manual
  Discolored areas in VHS capturesBy Sharc in forum Capturing and VCRReplies: 10Last Post: 30th May 2021, 07:55
  Which of these two methods is best to capture from VHS tapesBy crbd98 in forum Capturing and VCRReplies: 11Last Post: 16th Mar 2021, 11:59
  DIY VHS digitizer in 2019 via modern technologiesBy eobardthawne in forum Capturing and VCRReplies: 1Last Post: 9th Oct 2019, 15:25
  VHS captures are washed out.By Grandpa2390 in forum Newbie / General discussionsReplies: 7Last Post: 16th Nov 2018, 21:43
  VHS capture in 2016 - Best Methods? (with extensive equiptment availibilty)By teleskier in forum Capturing and VCRReplies: 8Last Post: 20th Jun 2016, 17:47
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
