If I want to convert video files with the exact quality (bitrate, resolution, etc.) to HEVC H265 which software achieves the fastest result? Is conversion using VGA going to generate faster results? Most of the converters that I have used have a slider-type setting to select the output quality. I just want the output file to be exactly (or as close as possible) to the input file. I just want to convert the format and/or container.
PS: It could be a paid or a free program.
For fastest H.265 encoding you would probably use any encoder which uses NVEnc which requires an NVIDIA card.
For fast H.265 software encoding you would use x265 with for example 'ultrafast' preset.users currently on my ignore list: deadrats, Stears555, marcorocchini -
I agree with jagabo and whether one uses MeGui, StaxRip, Hybrid, Handbrake or some ffmpeg based gui which offers NVEnc support doesn't really matter in terms of quality or performance it's more a question which GUI layout one prefers. (personally I would use Hybrid since I'm it's author, but it's explicitly not trying to be newbie friendly,..)
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
The 750 Ti's HEVC encoder doesn't even support b-frames. That's a huge strike against it in terms of quality per bitrate.
https://en.google-info.org/43585284/1/nvidia-nvenc.html
A Ryzen 9 3900X running x265 will probably beat a GTX 750 Ti in speed too. -
A Ryzen 9 3900X running x265 will probably beat a GTX 750 Ti in speed too.users currently on my ignore list: deadrats, Stears555, marcorocchini
H265/HEVC to H264/AVC
By Daringbaaz in forum Newbie / General discussionsReplies: 5Last Post: 22nd Sep 2019, 11:34 -
HEVC / H265 video conversion on Android
By Steve75 in forum Video ConversionReplies: 14Last Post: 21st Jul 2019, 02:42 -
H265/HEVC Hardware players like a Roku-type?
By rumplestiltskin in forum Newbie / General discussionsReplies: 3Last Post: 27th Jun 2017, 00:13 -
H265(HEVC) to H264 without loss of audio quality?
By pauljuhn in forum Video ConversionReplies: 5Last Post: 26th Mar 2017, 19:49 -
How do I Save my project in H265/HEVC ?
By Sloppy_turtle in forum Video ConversionReplies: 2Last Post: 3rd Feb 2017, 08:14
