I loaded a mpeg2 file that i created using TMPGenc into Ulead DVD movie factory, and burned the image unaltered(no chapters etc.) on my 104 dvdr drive. When i play back on my standalone player the film goes out of sync about half way in and ends up being several seconds out of sync! What have i done wrong?
play it back on your PC if it's fine then the problem is the DVD-r or your DVD player best Player for playing back burn DVD-r or CDR's APEX
When ulead converts back to vobs i loaded them in power dvd and the audio is still out of sync. The original mpeg file is ok! Is there another authoring prog i could try that doesn't cost an arm and a leg?
Go to the Ulead web site and download the audio/video sync patch. They play fine on my Panasonic and Sony DVD players. Avoid using generic DVD-Rs.
http://www.ulead.com/tech/dmf/dmf_ftp.htm
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
