Im trying to convert a
352x240 30fps MPEG-1 video
to a
352x240 29.97fps MPEG-1 NTSC video (same resolution).
I've followed the startup wizard in TMPGEnc and all seems to be fine until I click the start conversion, and it either locks up the program or comes up with the error message "Illegal Floating Decimal Point Calculation Order".
Im new to all this, and cannot find out why or how to fix elsewhere.
I run a 430mhz with 200mb ram, but its only a small 25mb video. So I wouldn't think its my system thats causing the problem.
Or does anyone know where I can find a manual/guide for using TMPGEnc, (heard it was one of the best Freeware programs available)
your error has nothing to do with the framerate...look at the top of the newbie forum--there is a sticky topic titled:Originally Posted by Paradox81
"illegal floating decimal" or something to that effect
in that post is the answer to your question
--also, read the post titled "read this before posting" -
My apologies :oops:,
I did have a quick look before I posted this message but found no answer that fixed my problem (Second look came up successful)
Incase anyone is wondering I found if you:
"One possible fix is to change the AVI file engine TMPGEnc uses. Try going to
1. Options
2. Environmental Settings
3. VFAPI Plugin
4. right click on 'Direct Show Multimedia File Reader'
5. select Higher Priority"
How do I convert 60fps to 30fps to halve file size?
By DigitalOxygen.ca in forum MacReplies: 33Last Post: 11th Jul 2012, 22:27 -
Convert FLV 25fps to 29.97fps
By Jason77 in forum Video ConversionReplies: 6Last Post: 17th Feb 2011, 17:34 -
Convert 30fps to 24fps skipping every 5th frame?
By DragonQ in forum EditingReplies: 7Last Post: 29th Jan 2011, 04:11 -
canon 5d mkII 30fps to 25fps best way to convert?
By powertase in forum Video ConversionReplies: 3Last Post: 20th Sep 2009, 22:53 -
Converting 30fps to 29.97fps ?
By blewyn in forum Video ConversionReplies: 2Last Post: 19th Mar 2008, 11:24
