I want to crop the material now. I checked with ffplay and this works:
ffmpeg -i WESTERBORK_2019_Resto(with_dupes_without_pretitles ).mp4 -filter:v "crop=693:520:134:10" -c:a copy Westerbork_cropped.mp4
how can I combine ths command with the framecount burn in?
ffmpeg -i Westerbork_cropped.mp4 -vf decimate=cycle=3,drawtext=fontfile=Arial.ttf:fonts ize=25:fontcolor=white:text=''%{frame_num}:borderc olor=black:borderw=2=20:y=20 Westerbork_cropped_framerate.mp4
Results 31 to 39 of 39
Add the crop and a comma between the -vf and decimate:
Code:-vf crop=693:520:134:10,decimate=cycle=3,drawtext...
Thanks!
And one more question about the framecount. I have another case, where I want to burn in a framecount with certain delay. There's a pretitle that shouldn't count, but doesn't have to be removed. Can I substract the exceeding number of frames?
ffmpeg -i Westerbork_cropped.mp4 -vf drawtext=fontfile=Arial.ttf:fontsize=25:fontcolor= white:text=''%{frame_num-120}:bordercolor=black:borderw=2
You'd think that would work but it doesn't. You can use "text='%{frame_num}': start_number=120" to start with frame number 120 instead of 0. But it doesn't accept a negative number. I don't have a solution for you.
Here's a way you can brute force it with a batch file. Basically, encode the first part without frame numbers, the second part with frame numbers, concatenate the two intermediate files to a third, remux to mp4, then delete the intermediate files:
Code:ffmpeg -y -i input.mp4 -to 00:00:04.8 part1.ts ffmpeg -y -ss 00:00:04.8 -i input.mp4 -vf drawtext=fontfile=C\\:/Windows/fonts/arial.ttf:fontcolor=white:text='%%{frame_num}':bordercolor=black:borderw=2:x=20:y=20 part2.ts copy/b part1.ts+part2.ts all.ts ffmpeg -y -i all.ts -c copy output.mp4 del part1.ts del part2.ts del all.ts -
you can use filter_complex graph
split the input - one with intro [a] , one with main [b] , and -vf trim the clips to desired range, where -vf drawtext framenumbering is applied to [b], then -vf concat for the output node
https://ffmpeg.org/ffmpeg-filters.html#trim
(note the end_frame arg is exclusive, not inclusive in ffmpeg -vf trim)
https://ffmpeg.org/ffmpeg-filters.html#toc-concat
ffmpeg is a bit tricky, in that everything runs on timestamps, so whenever you trim you need to insert a setpts filter
In this 600 frame, 25fps example, 0-99 (inclusive) is the intro , 100-599 (inclusive) is the main part that has drawtext applied (frame 100 would start with "zero")
Code:ffmpeg -i input.mp4 -filter_complex "split[a][b]; [a]trim=start_frame=0:end_frame=100,setpts=N/(25*TB)[a2]; [b]trim=start_frame=100:end_frame=600,setpts=N/(25*TB), drawtext=fontfile='C\:\\Windows\\Fonts\\Arial.ttf':fontsize=25:fontcolor= white:text=''%{frame_num}:black:borderw=2:x=20:y=20[b2]; [a2][b2]concat[out]" -map [out] -c:v libx264 -crf 20 -an output.mp4 -
a cool! Actually I don't need the intro anyway. I guess it would it be much easier to simply cut off the intro and then burn the framerate into th rest?
Yes. One line of my "brute force" batch file does exactly that, by time, not frame number. 120 frames at 25 fps is 4.8 seconds (120 / 25):
Code:ffmpeg -ss 00:00:04.8 -i input.mp4 -vf drawtext=fontfile=C\\:/Windows/fonts/arial.ttf:fontcolor=white:text='%%{frame_num}':bordercolor=black:borderw=2:x=20:y=20 output.mp4
Have you superscripts numbers using aegisub?
By Patapin in forum SubtitleReplies: 7Last Post: 8th Nov 2019, 04:30 -
JVC serial numbers?
By jtech1 in forum Newbie / General discussionsReplies: 0Last Post: 30th Dec 2018, 18:13 -
Why frame numbers in VirtualDub and Avisynth different?
By Megafox in forum Newbie / General discussionsReplies: 5Last Post: 15th Sep 2018, 12:56 -
Help me figure out the crop numbers
By blue24 in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2018, 14:15 -
Display Optional Frame Numbers?
By jfharper in forum EditingReplies: 3Last Post: 9th Feb 2017, 00:38
