I have just started playing with transcoding video with x265. Using MediaInfo to examine several other video files not encoded by me, in the "Encoding settings" field I will often see "total-frames=156607" or some other numeric value. Whenever I encode a video, MediaInfo always shows "total-frames=0". I don't know why this is. I'm not even sure what the total-frames setting is actually supposed to indicate. My guess would be the literal total number of frames in the video. But if that is the case, why do the videos I encode always have a value of 0? Looking at the documentation for x265, the only thing it says about total-frames is this:
If I try to pass the option "--total-frames" with the number of frames in the source video, or any other number, I get the error message "unknown option -- total-frames". Can anybody help me understand the meaning of the total-frames value, why mine is always 0 when other videos have actual values, how it can be changed and whether it makes a difference? Thanks!If --total-frames is 1, then a stillpicture variant will be signaled, but this parameter is not always set by applications, particularly not when the CLI uses stdin streaming or when libx265 is used by third-party applications.
So a quick look in the documentation:If I try to pass the option "--total-frames" with the number of frames in the source video.. unknown option -- total-frames"
https://x265.readthedocs.io/en/master/cli.html#cmdoption-frames--frames <integer>
The number of frames intended to be encoded. It may be left unspecified, but when it is specified rate control can make use of this information. It is also used to determine if an encode is actually a stillpicture profile encode (single frame)
the total-frames reported by mediainfo is the frame count indicated by the container which is written when the container is created, if the number of frames is unknown to the application writing the container using 0 is usually the solution.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
Can the "smoothness" or "blurred" look of x265 encodes be controlled?
By MishaPrada in forum Video ConversionReplies: 11Last Post: 26th Aug 2018, 01:29 -
"Lossless" NVENC bitrate vs x265
By savvyguy in forum Newbie / General discussionsReplies: 0Last Post: 18th Aug 2018, 22:28 -
Avisynth total frames does not equal VirtualDub total frames
By EasyFeet in forum EditingReplies: 12Last Post: 14th May 2017, 00:20 -
Finding individual "bad" frames in video and save frame number, or repair
By johnmeyer in forum RestorationReplies: 6Last Post: 13th Dec 2016, 20:59 -
!!! help - How to preserve the "bad" frames in conversion
By appleboy1977 in forum Video ConversionReplies: 4Last Post: 30th Aug 2016, 19:03
