Greetings, and I am sorry if this isnt the correct area for this, I wasn't 100% sure where to post it but basically I am just trying to find out if it is possible to burn an interactive blu-ray and / or DVD, (kinda' like those old "choose your own adventure books", if any of you have any idea what I am referring to lol)...I am trying to figure out if theres a way using a dvd remote or whatever to choose different paths at say the end of a chapter...and then route those divergent routes together in a cohesive manner.... This may be a dumb inquiry, so I apologize if it seems so.... I would greatly appreciate anyone who takes the time to help answer this for me though....
sincerely,
Zak
[PS i also apologize if this is a previously answered thread, I tried searching for it but didn't have any luck]
I changed your thread title so more people will help and welcome to the forums.
You need:
1. An authoring app that allows you to utilize much more of the spec than simpler authoring apps do. Particularly handy are those that allow you to manipulate the player's internal shift register memory, though that isn't necessary for the easier titles. For DVD: Scenarist, DVDMaestro, Encore (maybe), DVDArchitect (sort of), DVDStudioPro (Mac), a couple of others. Similarly on the BD side: Scenarist, Sony BluDiscStudio, a few other fairly expensive ones.
2. Organization. You need to map out what you want to do and how every path diverges or converges, and see what assets are necessary to cover every permutation - especially at the transitions and the jump points. Then you need to assemble and/or create those assets.
3. You also need a decent encoder that allows you to specify whether a particular frame is independent or not, so that you can smoothly & cleanly jump/switch paths, and those points MUST be independent in order for the switching to work properly and not glitch/hang/hold.
4. Depending on how you put things together, you may also want an app that supports multi-angle, seamless branching playlists, I-frame still slideshow, subpicture highlighting, and button-over-video features (and some of those choices will put special requirements on the encoding). These features vary depending on format, but are generally available across the formats.
5. Patience and fortitude.
ScottLast edited by Cornucopia; 5th Jun 2021 at 00:42.
In other words, you are going to need more than some hints from forum members here and simple "burning" software. What you described is a complex project requiring lots of work, expertise, and professional authoring tools.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Thank you very much for your insightful and enlightening replies...It is indeed much more complex of a project than I had guessed...(I knew it'd be more in depth than simply throwing the media in a normal burning program)...While some of the things that're needed and were listed are at least familiar to me, (in that I know what is being referred to, not that I have a deep understanding thereof) I have to admit there is a lot there that is still above my head...While I've realistically scrapped the idea for now, Would you be so kind as to perhaps point me in the right direction for beginning the long process of learning?(Less so to do the previously mentioned project and more so just for my own general pursuit of knowledge on the subject matter)..Thank you all for your time. Much appreciated.
Sincerely
ZakK
Can a Blu-ray player play Blu-ray video burned on a DVD?
By digicube in forum Blu-ray RippingReplies: 2Last Post: 16th Jan 2019, 01:11 -
Burn DVD on blu-ray
By DonGiovanni in forum Authoring (Blu-ray)Replies: 15Last Post: 7th Aug 2018, 12:59 -
Blu-ray Dolpy Atmos 7.1 to Flac 24-bit 7.1?
By Computerman1 in forum Blu-ray RippingReplies: 12Last Post: 10th Jan 2018, 06:28 -
Can I burn an entire serie on blu ray/dvd?
By NomsayinBrah in forum Authoring (Blu-ray)Replies: 4Last Post: 16th Oct 2017, 17:57 -
burn multiple DVD movies in 1 blu ray disc. can you help me?
By sendero in forum Newbie / General discussionsReplies: 5Last Post: 10th Aug 2016, 13:10
