  1. I've got a video file I'm trying to help someone with. They wanted to cut about 2 seconds from the middle, and not lose any quality so I figured vdub and direct stream copy.
    The video is a mov file, HEVC recorded from an iphone X, and while the video does open, its upside down in virtualdub2. I can export using file > export > stream copy which works, but the exported video is then upside down in the player.
    I checked the metadata in the video file and it has a flag set rotate = 180
    what do I do so that I don't need to apply a rotate filter? Is there a setting to change, or do I need to edit the metadata somehow?
    The last thing I tried is I installed ffmpeg vdub plugin and tried opening the video using that instead of the caching driver, but same thing.
    Thanks to everyone here in advance, you're all awesome!!
  2. Originally Posted by davexnet View Post
    thanks that might just work!
    adding that does make the video play correctly, I guess the video is taken upside down on apple phones and told to rotate in the player I do not like this approach but oh well
    thanks again, I'll post back if I need further assistance
