Looking for appropriate QTGMC settings for this AVC(BDAV) (Canon Legria HFG25 camera).
Goal is to deinterlace escaping flicker and shimmer, keeping details, but not oversmoothing.
(This is one of two materials that I'm dealing with now.)
Thanks.
MediaInfo about this file:
General
Format : BDAV
Format/Info : Blu-ray Video
File size : 1.91 GiB
Duration : 11 min 29 s
Overall bit rate : 23.7 Mb/s
Maximum Overall bit rate : 24.0 Mb/s
Recorded date : 2020-07-20 19:08:10+01:00
Writing application : Canon
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 2 frames
Format settings, GOP : M=3, N=12
Codec ID : 27
Bit rate mode : Variable
Bit rate : 22.7 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan type, store method : Separated fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.438
Stream size : 1.81 GiB (95%)
without a sample: use preset="Slower"Looking for appropriate QTGMC settings for this AVC(BDAV) (Canon Legria HFG25 camera).users currently on my ignore list: deadrats, Stears555, marcorocchini
Qtgmc-GUI. A simple encoder for your Qtgmc scripts.
By ProWo in forum Video ConversionReplies: 17Last Post: 4th Mar 2023, 03:01 -
what could be QTGMC settings for this DV(dvsd)?
By taigi in forum RestorationReplies: 19Last Post: 4th Jun 2021, 12:54 -
Help with QTGMC
By Xyena in forum Newbie / General discussionsReplies: 6Last Post: 22nd Sep 2020, 13:25 -
prevailing best method for converting .mp4/avc&aac into .mkv/avc&mp3 ?
By hydra3333 in forum Video ConversionReplies: 6Last Post: 31st Dec 2017, 20:24 -
AVC settings for iPad
By Yellit in forum Newbie / General discussionsReplies: 2Last Post: 7th Aug 2017, 13:05
