Looking for appropriate QTGMC settings for this DV(dvsd) (Panasonic NV-GS80 camera).
Goal is to deinterlace escaping flicker and shimmer, keeping details, but not oversmoothing.
(This is one of two materials that I'm dealing with now.)
Thanks.
MediaInfo about this file:
General
Format : AVI
Commercial name : DV
Format profile : OpenDML
File size : 9.48 GiB
Duration : 44 min 37 s
Overall bit rate mode : Constant
Overall bit rate : 30.4 Mb/s
TAPE : (Unknown)
TCOD : 28800000
TCDO : 26801600000
VMAJ : 4
VMIN : 0
STAT : 66932 0 3.433375 1
DTIM : 0 0
Video
Format : DV
Codec ID : dvsd
Codec ID/Hint : Sony
Bit rate mode : Constant
Bit rate : 24.4 Mb/s
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Bottom Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 2.357
Time code of first frame : 00:00:02:22
Time code source : Subcode time code
Stream size : 8.98 GiB (95%)
Results 1 to 20 of 20
without a sample: use preset="Slower"Looking for appropriate QTGMC settings for this DV(dvsd) (Panasonic NV-GS80 camera).users currently on my ignore list: deadrats, Stears555, marcorocchini
No clue where those vertical lines come from, but after deinterlacing, you probably want to do something like:
So all in all I wouldCode:TurnLeft() SOME-AA-FILTER() TurnRight()
1. Deinterlace with QTGMC 'slower'
2. AA as described above
3. do some denoising
here's a picture after QTGMC + AA:
so one would probably add some denoising, contrast sharpening and color adjustments depending on personal preferences.
Cu SelurLast edited by Selur; 3rd Jun 2021 at 11:44.
users currently on my ignore list: deadrats, Stears555, marcorocchini -
Thanks.
Using dehalo and Santiag for AAing vertical lines (thanks for one user of this forum) already.
Can I tune QTGMC in any way?
Not for vertical lines, but maybe it ads some extensive smoothing?
Or maybe that doesn't matter, since video after AA is already hyper smooth. -
I don't think that anything you can do with QTGMC will really survive the 'flipped' AA which is needed to get rid of those vertical lines,...
Trying to save on pennies here since they are still money?
A horizontal downscale/upscale would suppress the vertical line artefacts as well, something like
Code:bilinearresize(620,576).spline36resize(720,576)
Why bilinear for downscale? What about spline for downscale too? And what about spline64?
Fix lines, keep grain/details:
Code:LWlibavVideoSource("deinterDV.mp4") SeparateFields() san = Santiag(strh=0, strv=1) emask = mt_lutxy(san, last, expr="x y - Abs", chroma="-128").mt_binarize(4).mt_expand(chroma="-128").Blur(1.4) Overlay(san, mask=emask) Weave() QTGMC(Sharpness=0.5, EZKeepGrain=1.0)Last edited by jagabo; 4th Jun 2021 at 11:27.
@jagabo, so this would be better then bilinearresize(620,576).spline36resize(720,576)?
Why don't you compare for yourself?
You can also combine the two:
Code:LWlibavVideoSource("deinterDV.mp4") SeparateFields() src = last san = Santiag(strh=0, strv=1) emask = mt_lutxy(san, src, expr="x y - Abs", chroma="-128").mt_binarize(4).mt_expand(chroma="-128").Blur(1.4) BilinearResize(620,height).Spline36Resize(720,height) Overlay(src, BilinearResize(620,height).Spline36Resize(720,height), mask=emask) Weave() QTGMC(Sharpness=0.5, EZKeepGrain=1.0)Last edited by jagabo; 4th Jun 2021 at 11:39.
@jagabo, what about this one then:
QTGMC()
dehalo_alpha(rx=2.5, ry=2.5, brightstr=1.2, lowsens=0, highsens=50)
santiag(strv=3, type="nnedi3", nns=4, threads=0, nsize=4, halfres=false, scaler_post="Spline64Resize") -
if the output is fine: good
simply looking at the output of the script might help,....
like I wrote I think it's a waste of time,...What about SourceMatch=3, Lossless=2?users currently on my ignore list: deadrats, Stears555, marcorocchini -
Something apparently surviving as per my experiment.I don't think that anything you can do with QTGMC will really survive the <...> AA
Happy that you did experiment.Something apparently surviving as per my experiment.users currently on my ignore list: deadrats, Stears555, marcorocchini
Qtgmc-GUI. A simple encoder for your Qtgmc scripts.
By ProWo in forum Video ConversionReplies: 17Last Post: 4th Mar 2023, 03:01 -
Help with QTGMC
By Xyena in forum Newbie / General discussionsReplies: 6Last Post: 22nd Sep 2020, 13:25 -
I think this just needs QTGMC...
By pooksahib in forum Video ConversionReplies: 2Last Post: 30th May 2019, 04:12 -
Help with QTGMC?
By attackworld in forum EditingReplies: 3Last Post: 26th Nov 2018, 22:57 -
dvsd fourcc is only for SD material? o also HD
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 18th Mar 2017, 21:59
