I have several video files with low volume. I need a simple way to increase the volume of the files, say by 15-20bd.
Results 1 to 9 of 9
replay gain normalization is available for aac in mp4. foobar 2K does it.
Use clever FFmpeg-GUI.
Increase the volume as desired. Alternatively, you can use the DynAudNorm (Dynamic Audio Normalization) filter.
You can also run the automatic audio analysis before the conversion. -
Thanks but I use Avidemux for my mp4's with aac. What I need is something for wmv's. I can use Avidemux to convert to mp4/aac but I'd like to just increase the volume without changing the video.
I tried clever FFmpeg-GUI but an unhandled exception occurred in my wmv and mp4 files.
As I replied to butterw: I use Avidemux for my mp4's with aac. What I need is something for wmv's. I can use Avidemux to convert to mp4/aac but I'd like to just increase the volume without changing the video. -
You should be able to re-encode the audio without re-encoding video. Try selecting mkv as the output container.
Replay-gain which is available for aac and mp3 doesn't require re-encoding. -
Try using BS Fag if that fails to increase the audio due to the normalizer then Free Video Volume Booster will definitely perform the task as you can manually adjust it to your specific needs.I've tested it on a wmv sample both are available to download on this site.
How can I increase the speech volume on MKV movies?
By taken21 in forum AudioReplies: 3Last Post: 26th Jan 2019, 02:32 -
Convert audio part of a video and increase volume by 30% wiht ffmpeg?
By pxstein in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2017, 05:06 -
HOW TO INCREASE AUDIO VOLUME IN A AVI FILE USING VIRTUAL DUB
By fgtan in forum Video ConversionReplies: 14Last Post: 13th Dec 2016, 13:54 -
How to Increase Audio Level (Volume), Once Extracted - ?
By elling in forum AudioReplies: 5Last Post: 21st Jun 2016, 15:27 -
Mini How To - Increase Your AC3 Volume
By Soopafresh in forum AudioReplies: 113Last Post: 10th Jun 2016, 06:44
