i want to compress all the music cds they just collect dust now using dbpoweramp and store them on a 128gb sd card as i have not used any of my music cds in like 4years or so
i worked out if each song was 5mins i could fit something like 16,000 on it at 180kbps since most songs are under 5mins it will fit a lot more
also for me i can't really even notice much of a diffrence compressing cds to Opus 2pass at 180kbps then if i was listening to the cd
is Opus the best or is there something even better?
Results 1 to 16 of 16
Since you can't hear the difference the issue isn't which audio codec is best. It's what format is compatible with all the devices you might want to use for playback.
No. You're wrong.
There's not a best compression at all.
Lossless is the only way (at least with audio.. ) if you want to preserve information and QUALITY, I mean.
But most people love youtube quality ( = totally SHIT) -
Lossless stereo (ex: Flac) can't be achieved at 180kbps and most people can't hear the difference with opus or aac.
You might want to rethink that. You say you cannot tell the difference between lots of compressed stuff vs uncompressed, and that may be true. It might only be true right now, at 1st glance, however. And when you start listening to a LOT of stuff, you might start being able to discern more and more the detriment that compressed files are doing to the music.
I've started going back through my large collection and am re-ripping to LPCM WAV or to lossless codecs (FLAC, ALAC...) because it is becoming more and more obvious how lossy compression is wearing on the listener. The LPCM/lossless stuff has more "life", better definition, and is less grating and is more silky & scintilating, especially in the high end. When can you say that about lossy-compressed stuff?
Remember, overall, space is cheap!
Scott -
For reference:
https://forum.videohelp.com/threads/401491-best-mp3-encoder#post2616871
He already says he can't hear the difference. When he says "something better by now" what does he mean? -
It's only true if you have really good audio equipment,can you tell me that you can hear the different on a 320mbps mp3 compared to a flac version if the original cd was done to both?
to preserve the original quality → FLAC
to compress [losing quality] → OPUS [192kbps] is equal to or better than MP3 [320kbps]
only compares the spectrum analysis with SPEK opus reaches up to 20khz the same as mp3, only opus needs less bitrate.
[Attachment 60037 - Click to enlarge] -
Best free lossy ? - probably yes.
Why are you comparing two different cases? 48000 vs 44100Hz sample rates? side to this occasional peaks above 20kHz may be a symptom for a hard clipped audio (levels above 0dBFS)...
For fair comparison use some source with spectrum above 24kHz and provide as reference (for example 192kHz resampled to 48kHz).Last edited by pandy; 26th Jul 2021 at 16:53.
hell if you are over forty you can't hear anything of 15khtz anyway.... may as well stick with something like vbr mp3 to make the smallest files.
Because Opus is only allowed to 48000Hz (if input is not 48000Hz, Opus will ENFORCE resampling)
Source: https://wiki.xiph.org/OpusFAQ#How_do_I_use_44.1_kHz_or_some_other_sampling_rate_not_di...orted_by_Opus? -
MKV opus audio converting
By Kracov in forum Video ConversionReplies: 24Last Post: 31st Dec 2020, 11:47 -
OPUS Format
By biferi in forum Newbie / General discussionsReplies: 23Last Post: 7th Jul 2020, 20:41 -
Trim Opus and FLAC tracks
By Knocks in forum AudioReplies: 1Last Post: 20th Nov 2019, 02:15 -
AVIdemux can't handle Opus multichannel
By bizzybody in forum Video ConversionReplies: 0Last Post: 11th Feb 2019, 16:32 -
Opus to Mp3?
By sagor in forum AudioReplies: 10Last Post: 10th Mar 2018, 00:41
