  1. Every time i run the program, i get a message:
    "Some files are still locked
    Try unlock with a player"
    I also have similar problems with DVDdecryptor.
    I never used to have this problem, and has only recently come about.
    I'm not sure what 'files locked' means.
    Could someone possibly explain that?
    How do i go about fixing this problem?
    Thanks in advance
  2. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    Hi,
    did you try this:
    Play the DVD for a few seconds on your PC. This should normally unlock the drive.
    The Dutchman
    May 2002
    Australia
    Usually, this message will only appear on Windoes NT based systems (2000, XP, etc)... try installing an ASPI layer, and you won't need to run PowerDVD etc to rip the DVD. (At least, i don't...)
    Cheers,
    Glen.
