It does have miniDV player on the left side. I tried connecting it directly to the Dazzle device along with the S-Video cable and it had more video/audio problems while capturing to my computer. At this point I think that either the Dazzle device is not that great or I may try converting the miniDV tapes to VHS then convert them with my other video capture device that I know works.
I am getting a second opinion from a family member that works with computers to see if they can get it to work.
I do thank all of you for all the advice you have given and will keep you informed of my progress.
Jon
Results 31 to 39 of 39
Jon, you could try S-video into your other device (what is it, if you don't mind me asking?). Going via the DV>VHS>capture route would be worst way of doing this.
I've just made a 4:3 DV recording and captured it from the Hv20 successfully, in good quality, from the Composite port to my GV-USB2 with Virtual Dub. I think the Dazzle may be the problem point.
Minor Update. My Uncle was able to get the proper firewire and a mac with the proper port. The results turned out well so now he is waiting for a usb-c adapter in order to see if the process will work on his surface pro. It seems that the Dazzle video capture device was the problem.
Thank you all again for your help.
Jon -
Jon, You won't find a cheap Firewire-USB C adapter.
I do not have a clue about Macs, but I'd try copying the videos from the Mac onto an external USB 3 drive and transferring them to the Surface that way (or indeed just leaving them on the external drive for editing on the Surface). -
I have the proper set up now to import my tapes. I have a Mac with a firewire port and the proper firewire from the camcorder to the computer. iMovie is able to import the miniDV tapes and the video looks great. However I now have a new problem. I do not know how to use iMovie to properly import a tape as I have never used it before. I figured out how to put the clips from the importing process into one file but the audio is missing and I do not know why. The audio plays fine through the camcorder but will not play on the files that I make. Is there a setting that I am missing or an extra step that I have to take? I know that I ask this a lot but what am I doing wrong?
Jon -
You would be better off starting a new thread specific to this issue on the Mac forum.
But, initially, to test that you actually did transfer audio load a transferred clip in to a bespoke Mac player such as quicktime or iTunes.
But I would have thought that iMovie will have to re-encode the imported clips since they are, if I understand correctly, in a .mov container
And you can always post a mediainfo report of one of the clips (might have to transfer that to a PC first) for clarification of the transferred format and qualities.
many miniDV tapes - need to rip
By mcouture in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 5th Jan 2021, 17:36 -
Archiving MiniDV tapes but they all start to have audio skipping
By hpcampr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 19th Feb 2020, 13:18 -
minidv tapes breaking up
By hdfills in forum Capturing and VCRReplies: 2Last Post: 29th Nov 2018, 18:48 -
Why is the audio distorted on these MiniDV tapes?
By Hypersonic1 in forum Capturing and VCRReplies: 14Last Post: 18th Apr 2018, 20:04 -
How to transfer minidv video tapes to digital videos
By OldViddy in forum User guidesReplies: 6Last Post: 4th Dec 2016, 10:54
