  1. There's a app that provides a number of free tv channels. I wanted to extract the m3u8 links and play them in my Libreelec/KODI Setup to watch them in bigscreen. I used wireshark to extract the link but it only works for a few minutes and then I would again have to extract the link (might be due to the token expiring). Here's the image of the POST method header or whatever it is called that the app used to extract channel.
    [Attachment 59119 - Click to enlarge]
    Host: 62.210.172.84
    Accept-Encoding: gzip
    Connection: Keep-Alive
    Content-Length: 126
    Content-Type: application/x-www-form-urlencoded; charset=UTF-8
    User-Agent: Dalvik/2.1.0 (Linux; U; Android 11; M2007J22C Build/RP1A.200720.011)
    And the app says that every link used in the app are from the internet, so I don't think this is breaking any rules.
    And should I upload the pcapng file too??
    I really hope that I will find my answer here.
  2. you have the "URL" and "Request Headers" but you are missing DATA that is being sent to that URL.
    https://imgur.com/lZ2Ufp3
    discord=notaghost9997
  3. notaghost,
    would that be in the pcapng file then?
    Here's the pcap file, I don't know much about it so... sweat_smile
    https://send.vis.ee/download/28ec95e59d00746a/#8Snce3Ho1Jtt2Tk4fRYIrA
