Results 1 to 16 of 16
    Feb 2021
    I got movie in HDR described as Atmos DV. When I play it I have violet Elephants and green sky I'm using madVR.
    MediaInfo:
    HDR format: Dolby Vision, Version 1.0, dvhe.05.06, BL+
    Bit depth: 10 bits
    Codec configuration box: hvcC+dvcC
    What is this and how to get valid colors?
  2. What is this and how to get valid colors?
    Afaik there is no software decoder which can decode Dolby Vision (Atmos is probably related to the audio not the video) outside of Dolby Vision authoring software.
    To your questions:
    a. it's HDR content not properly decoded
    b. use a hardware player that supports Dolby Vision
    (c. find and sponsor someone to reverse engineer Dolby Vision and write a patch for libav for it)
    Feb 2021
    Now I see in description:
    mixed dolby vision file. There is a very limited amount of devices that can play dv muxed this way
    On Dolby wensite is some sample, but there is nothing special in this, just brighter.
    https://www.dolby.com/technologies/dolby-vision/
    Need dedicated hardware to watch movies, so I don't find it useful.
    But maybe this is only for cinemas? Is it better than other hdr?
  4. But maybe this is only for cinemas?
    nope, it's meant for consumer hardware.
    (when I write HDR10 this includes HDR10+)
    potentially: yes
    in praxis: not really
    https://www.heimkinoraum.de/tests/dolby-vision-vs-uhd-premium-hdr10-166 (<- nice, rough overview in german)
    -> I would recommend to use HDR10+ instead
    Cu Selur
  5. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Zidoo UHD3000 does Dolby Vision DV assuming your TV also supports Dolby Vision.
  6. @netmask56: So that does mean the 'Zidoo UHD3000' is able to passthrough DV to the display, right? It doesn't come with a DV decoder chip or similar.
  7. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Model UHD3000
    Front Display LED
    Chassis Aviation aluminum alloy
    OS Android 9.0
    CPU Realtek RTD1619DR ARM Cortex-A55(hexa-core)
    GPU ARM Mali-G51 MP3
    RAM 4GB DDR4
    Internal Storage 32GB eMMC
    Bluetooth BT 4.2
    WiFi 2.4G+5G dual band WiFi, 802.11 a/b/g/n/AC 2T2R MIMO 867Mbps
    Ethernet 1*RJ-45(10/100/1000Mbps)
    HDMI Output 2.0a (4K@60fps/12Bit/HDR/BT2020/YCbCr 4:4:4 output) + 1.4 (Audio Only passthrough) separate audio and video output
    Video Decoding 4K@60p,HEVC/H.265 12Bit,HDR10,HDR10+,Dolby Vision
    Audio Decoding Support HD audio passthrough and decode 2 channels
    Built-in XMOS+ESS 9068 DAC,supporting DSD、MQA decoding
    USB Audio Input USB audio input supports Windows 7, Windows 10, Mac and Android
    Up to two channels DSD512, PCM 768KHz@32bit PCM, MQA decoding
    Other Audio Port 1*Optical,1*Coaxial,1*RCA L/R,XLR L/R balanced
    Analog Audio Characteristics Frequency range: 20Hz-20KHz +/-0.35dB
    SNR: > 128dBrA
    THD+N: < 0.00026%
    Output level: (XLR) 4.0±0.4Vrms. (RCA) 2.0±0.2Vrms.
    DNR: > 125dB
    Crosstalk: > 135dBrA
    Power Supply AC 110~120/220~240V 50/60Hz (built-in switching power supply + linear power supply)
    USB 2*USB3.0,2*USB2.0
    SATA 2*SATA3.0 and 3.5" HDD bay (HDD is not included)
    Other Ports 1*IR input,1*RCA composite video connector,1*RS232
    Dimensions 312mm*430mm*72mm
    Accessories 1*remote control,1*power cable,2*antennas,1*user manual
  8. Presumably it should look more like this. I captured the image from this web page, loaded it into Gimp and hue shifted it by +75.
    From that I would assume the problem is a chroma phase shift which should be easy to correct with standard editing tools.
    Brian.
    [Attachment 59164 - Click to enlarge]
  9. @betwixt: Sure, but like HDR10+, DolbyVision has hdr data per frame, so adjusting the hue etc might work on one frame, but you would potentially have to adjust hue&co differently for each frame.
    Feb 2021
    Another question on DV. I have got mopic in DV, Image colors are not correct in player, but some short parts are displayed correctly, in others they are more to correct than incorrect. Why?
    Format                         : HEVC
    Format/Info                    : High Efficiency Video Coding
    Format profile                 : Main 10@L4@Main
    HDR format                     : Dolby Vision, Version 1.0, dvhe.05.03, BL+RPU
    Codec ID                       : V_MPEGH/ISO/HEVC
    Duration                       : 59 min 42 s
    Bit rate                       : 5 581 kb/s
    Width                          : 1 920 pixels
    Height                         : 1 080 pixels
    Display aspect ratio           : 16:9
    Frame rate mode                : Constant
    Frame rate                     : 23.976 (24000/1001) FPS
    Color space                    : YUV
    Chroma subsampling             : 4:2:0
    Bit depth                      : 10 bits
    Bits/(Pixel*Frame)             : 0.112
    Stream size                    : 2.33 GiB (36%)
    Default                        : Yes
    Forced                         : No
    Color range                    : Full
  11. Wild guess is that the player does not support the Dolby Vision profile (dvhe.05.03).
    You might want to read
    https://www.diversifiedvideosolutions.com/Dolby_Vision/Dolby_Vision_profiles_and_level...boratories.pdf
    in regard to profiles compatibility together with th description of your player in regard to which profiles it supports.
    Cu Selur
  12. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    MediaInfo:
    Bit depth: 10 bits
    An obvious question but maybe? Does your TV support Dolby Vision ? I had a client who had quite a few DV UHD discs and files and kept complaining he couldn't get DV to work even tho' his media player did. It turned out his TV whilst new, a Samsung, didn't support DV
    Feb 2021
    Player = MPC-HC I know DV requires special decoder that is not supported by most devices, but strange in this mopic is that some short scenes has correctly decoded colors
    I have Samsung (definitely non-)smart TV, 3yo, and I have already got used to that it is good for television only, for movies and so on it is completely not suitable - does not support most A/V codecs, do you believe that? It even doesn't support full specification of Matroska...
  14. There is no DolbyVision software decoder, especially not in libav so MPC-HC can't decode the dv data, but only passthrough the dv data to the display (assuming it's configured to do so).
    If your display does not support dv then you can't properly play the file.
    Seeing some scenes that seem 'correct' only means that the dv data in these scenes does not alter the appearance much.
    -> If you want DolbyVision you need either a display which supports it (comes with it's own DV decoder) or a software player which does HDR-DV to SDR, since there isn't such a player available and it doesn't seem like Dolby is creating one you can't playback the file properly.
    Cu Selur
    Aug 2006
    Under those circumstances, you can only play files with HDR10 and even then you must use software players that can perform tone mapping in some way.
  16. Member Ennio's Avatar
    May 2005
    Netherlands
    ...So that does mean the 'Zidoo UHD3000' is able to passthrough DV to the display, right? It doesn't come with a DV decoder chip or similar.
    Zidoo RDT1619DR based mediaplayers have the Dolby Vison VS10 engine onboard, which is hardware. This engine can perform DV content tonemapping and put it out as LLDV, or put DV out as "TV-led", in which case the TV will do the tone-mapping. Eventhough these players are able to playback DV content that carry a Full Enhancement Layer (FEL), they do lack a second HEVC decoder for it. So you'll miss out on the FEL's 10 to 12 bit differential data. There is of course discussion going on whether or how much this extra data would add to a better picture.
    Having such a player, I must say it performs well with all kinds of video-content. Next to the Dolby Vision capabilities, Zidoo has also made big leaps forward with HDR/DV to SDR conversion quality. Which is still important to a lot of non-4K/HDR/DV display owners.
