  1. I tried cropdetect and then cropped using values provided by it. I used a test video of 576p (1024 X 576) so after cropping it became 1088 X 432.
    so is there any way to keep the width standard. like 1024 is for 576p and 1280 for 720p. Handbrake does this by managing height. I want to do similar with ffmpeg but I'm not able to find any proper command or flag for that.
    Thank You !
  2. Standard Width for 576 is 720 (PAL), not 1024.
    To have standard width you must resize after cropping.
  3. Originally Posted by ProWo View Post
    Sorry I forgot to mention. I'm talking about BluRay encode. not DVD.
  4. Member DB83's Avatar
    Jul 2007
    But your 576p example does not make any sense.
    You appear to be describing non-anamorphic widescreen which fits the widescreen in a 4:3 frame (typically 72 lines of border top and 72 lines bottom). Thus 576 - 144 = 432.
    Before the crop that then displays as 768*576 - 1024*576 is reserved for anamorphic widescreen (576/9*16 = 1024).
    Crop the bars to retain the 16:9 gives you 432/9*16 which brings you back to your original display width of 768 pixels.
    Sorry. I can not assist with ffmpeg commands. This is just the underlying theory.
