This is the first time in two dozen tries that a disc wouldn't burn. The prior 20 or so had no issues and so I had no indication this was coming. Nothing changed between disc 1 and this attempt which other than the result. If none of my BD-R discs would burn, that would be different but they all burned like they should up until now.
-------------------------- 5/26/21 12:55:28 AM --------------------------
5/26/21 12:55:28 AM.413: DLLAV32.DLL loaded, all entry points available
5/26/21 12:55:28 AM.453: AVSDK MsgCbFunc registered
5/26/21 12:55:28 AM.455: AVSDK: StatCbFunc registered
5/26/21 12:55:28 AM.656: AVSDK Version 13.0.244
5/26/21 12:55:28 AM.658: ------------ Reading Device Info ----------------
5/26/21 12:55:28 AM.660: AVSDK: 2 device(s) found
5/26/21 12:55:28 AM.661: BurnSupport: 2 device(s) found
5/26/21 12:55:28 AM.663: Adapter=0 ID=0 LUN=16 D:TSSTcorp CDDVDW SU-208FB Revision:TF01
5/26/21 12:55:28 AM.665: Adapter=255 ID=2 LUN=0 F:HL-DT-ST BD-RE WP50NB40 Revision:1.03
5/26/21 12:55:28 AM.668: BurnSupport: 2 record device(s) available
5/26/21 12:55:28 AM.669: BurnSupport: D: TSSTcorp CDDVDW SU-208FB Rev. TF01
5/26/21 12:55:28 AM.671: BurnSupport: F: HL-DT-ST BD-RE WP50NB40 Rev. 1.03
5/26/21 12:55:28 AM.673: ------------ done ----------------
5/26/21 12:55:29 AM.397: setting no speed limit
5/26/21 12:55:29 AM.415: !!! DBK error in CBurnDevSupport::InvalidateDiscInfo(): 16 - burn support - invalid device !!!
5/26/21 12:55:31 AM.584: AVSDK Message - ERROR: :Cannot get device/media specific information -> functionality is not provided by device or by system
5/26/21 12:55:33 AM.866: AVSDK Message - ERROR: :Cannot get device/media specific information -> functionality is not provided by device or by system
5/26/21 12:55:35 AM.975: AVSDK Message - ERROR: :Cannot get device/media specific information -> functionality is not provided by device or by system
5/26/21 12:55:35 AM.997: Open Project: Filename -- bd project 2021-05-26
5/26/21 12:55:35 AM.998: VideoMode: NTSC Temp Dir: C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\
5/26/21 12:55:35 AM.999: dll version 6.0.10.28
5/26/21 12:55:37 AM.974: Open Project: temp -- bd project
5/26/21 12:55:37 AM.975: VideoMode: PAL Temp Dir: C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\
5/26/21 12:55:38 AM.026: Step 1 of 11, Encoding movie 1 ...
5/26/21 12:55:38 AM.035: Step 1 done
5/26/21 12:55:38 AM.041: Step 2 of 11, Encoding movie 2 ...
5/26/21 12:55:38 AM.050: Step 2 done
5/26/21 12:55:38 AM.056: Step 3 of 11, Encoding movie 3 ...
5/26/21 12:55:38 AM.063: Step 3 done
5/26/21 12:55:38 AM.072: Step 4 of 11, Encoding movie 4 ...
5/26/21 12:55:38 AM.080: Step 4 done
5/26/21 12:55:38 AM.087: Step 5 of 11, Encoding movie 5 ...
5/26/21 12:55:38 AM.094: Step 5 done
5/26/21 12:55:38 AM.102: Step 6 of 11, Encoding movie 6 ...
5/26/21 12:55:38 AM.109: Step 6 done
5/26/21 12:55:38 AM.117: Step 7 of 11, Encoding movie 7 ...
5/26/21 12:55:38 AM.124: Step 7 done
5/26/21 12:55:38 AM.131: Step 8 of 11, Encoding movie 8 ...
5/26/21 12:55:38 AM.139: Step 8 done
5/26/21 12:55:38 AM.157: ConvertMovie() - encoded file: C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\STREAM\00000.m2ts
5/26/21 12:55:38 AM.160: ConvertMovie() - encoded file: C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\STREAM\00001.m2ts
5/26/21 12:55:38 AM.165: ConvertMovie() - encoded file: C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\STREAM\00002.m2ts
5/26/21 12:55:38 AM.168: ConvertMovie() - encoded file: C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\STREAM\00003.m2ts
5/26/21 12:55:38 AM.171: ConvertMovie() - encoded file: C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\STREAM\00004.m2ts
5/26/21 12:55:38 AM.174: ConvertMovie() - encoded file: C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\STREAM\00005.m2ts
5/26/21 12:55:38 AM.177: ConvertMovie() - encoded file: C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\STREAM\00006.m2ts
5/26/21 12:55:38 AM.181: ConvertMovie() - encoded file: C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\STREAM\00007.m2ts
5/26/21 12:55:38 AM.280: Step 9 of 11, Creating DVD image...
5/26/21 12:55:38 AM.304: Step 9 done
5/26/21 12:55:38 AM.415: AVSDK Message - ERROR: :Cannot get device/media specific information -> functionality is not provided by device or by system
5/26/21 12:55:40 AM.528: AVSDK Message - ERROR: :Cannot get device/media specific information -> functionality is not provided by device or by system
5/26/21 12:55:40 AM.559: Step 10 of 11
5/26/21 12:55:40 AM.570: Step 10 done
5/26/21 12:55:40 AM.589: requested recorder feature:
5/26/21 12:55:40 AM.590: cache size: 16.000000.1 MB
5/26/21 12:55:40 AM.591: write speed: 26343.750000.1 KB/s
5/26/21 12:55:40 AM.592: book type: 0
5/26/21 12:55:40 AM.592: burn over: no
5/26/21 12:55:40 AM.593: simulate: no
5/26/21 12:55:40 AM.594: disc at once: no
5/26/21 12:55:40 AM.596: burn proof: yes
5/26/21 12:55:40 AM.597: format disc: no
5/26/21 12:55:40 AM.598: short leadout: no
5/26/21 12:55:40 AM.599: no defect mgmt: no
5/26/21 12:55:40 AM.600: verify after burn:no
5/26/21 12:55:40 AM.601: ------------ OpenRecorderSetOptions Point ----------------
5/26/21 12:55:40 AM.648: setting PoINT cache size to 16777216l
5/26/21 12:55:40 AM.656: Used burn options:
simulation: off
DiscAtOnce: off
BurnOver: off
BurnProof: on
FormatDisc: off
ShortLeadOut: off
NoDefectMgmt: off
5/26/21 12:55:40 AM.657: Booktype: don't care
5/26/21 12:55:40 AM.661: setting write speed to 26976000 bytes/sec
5/26/21 12:55:40 AM.662: this equals 19.477257x DVD / 152.925171x CD Speed
5/26/21 12:55:40 AM.663: ------------ done: succeeded ----------------
5/26/21 12:55:40 AM.664: ------------ CreateAPIProject ----------------
5/26/21 12:55:40 AM.668: Step 11 of 11
5/26/21 12:55:40 AM.673: creating BD project in prepfile mode...
5/26/21 12:55:40 AM.706: create volume... OK
5/26/21 12:55:40 AM.707: verify option OFF
5/26/21 12:55:40 AM.708: ... deleting "VIDEO_TS" in disc image
5/26/21 12:55:40 AM.709: set project options... OK
5/26/21 12:55:40 AM.742: creating directory "BDMV"
5/26/21 12:55:40 AM.757: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\index.bdmv"
5/26/21 12:55:40 AM.762: creating directory "BDMV"
5/26/21 12:55:40 AM.775: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\MovieObject.bdmv"
5/26/21 12:55:40 AM.781: creating directory "BDMV"
5/26/21 12:55:40 AM.782: creating directory "BACKUP"
5/26/21 12:55:40 AM.796: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\BACKUP\index.bdmv"
5/26/21 12:55:40 AM.802: creating directory "BDMV"
5/26/21 12:55:40 AM.803: creating directory "BACKUP"
5/26/21 12:55:40 AM.817: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\BACKUP\MovieObject.bdmv"
5/26/21 12:55:40 AM.822: creating directory "BDMV"
5/26/21 12:55:40 AM.823: creating directory "AUXDATA"
5/26/21 12:55:40 AM.828: creating directory "BDMV"
5/26/21 12:55:40 AM.830: creating directory "BDJO"
5/26/21 12:55:40 AM.835: creating directory "BDMV"
5/26/21 12:55:40 AM.836: creating directory "JAR"
5/26/21 12:55:40 AM.840: creating directory "BDMV"
5/26/21 12:55:40 AM.841: creating directory "META"
5/26/21 12:55:40 AM.846: creating directory "CERTIFICATE"
5/26/21 12:55:40 AM.860: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\CERTIFICATE\id.bdmv"
5/26/21 12:55:40 AM.867: creating directory "CERTIFICATE"
5/26/21 12:55:40 AM.868: creating directory "BACKUP"
5/26/21 12:55:40 AM.883: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\CERTIFICATE\BACKUP\id.bdmv"
5/26/21 12:55:40 AM.887: creating directory "BDMV"
5/26/21 12:55:40 AM.889: creating directory "BACKUP"
5/26/21 12:55:40 AM.890: creating directory "BDJO"
5/26/21 12:55:40 AM.894: creating directory "BDMV"
5/26/21 12:55:40 AM.896: creating directory "STREAM"
5/26/21 12:55:40 AM.910: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\STREAM\00008.m2ts"
5/26/21 12:55:40 AM.916: creating directory "BDMV"
5/26/21 12:55:40 AM.917: creating directory "PLAYLIST"
5/26/21 12:55:40 AM.931: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\PLAYLIST\00008.mpls"
5/26/21 12:55:40 AM.936: creating directory "BDMV"
5/26/21 12:55:40 AM.937: creating directory "BACKUP"
5/26/21 12:55:40 AM.938: creating directory "PLAYLIST"
5/26/21 12:55:40 AM.953: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\PLAYLIST\00008.mpls"
5/26/21 12:55:40 AM.958: creating directory "BDMV"
5/26/21 12:55:40 AM.959: creating directory "CLIPINF"
5/26/21 12:55:40 AM.974: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\CLIPINF\00008.clpi"
5/26/21 12:55:40 AM.979: creating directory "BDMV"
5/26/21 12:55:40 AM.980: creating directory "BACKUP"
5/26/21 12:55:40 AM.981: creating directory "CLIPINF"
5/26/21 12:55:40 AM.995: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\CLIPINF\00008.clpi"
5/26/21 12:55:41 AM.000: creating directory "BDMV"
5/26/21 12:55:41 AM.001: creating directory "STREAM"
5/26/21 12:55:41 AM.016: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\STREAM\00000.m2ts"
5/26/21 12:55:41 AM.021: creating directory "BDMV"
5/26/21 12:55:41 AM.022: creating directory "PLAYLIST"
5/26/21 12:55:41 AM.037: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\PLAYLIST\00000.mpls"
5/26/21 12:55:41 AM.042: creating directory "BDMV"
5/26/21 12:55:41 AM.043: creating directory "BACKUP"
5/26/21 12:55:41 AM.044: creating directory "PLAYLIST"
5/26/21 12:55:41 AM.058: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\PLAYLIST\00000.mpls"
5/26/21 12:55:41 AM.064: creating directory "BDMV"
5/26/21 12:55:41 AM.065: creating directory "CLIPINF"
5/26/21 12:55:41 AM.079: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\CLIPINF\00000.clpi"
5/26/21 12:55:41 AM.084: creating directory "BDMV"
5/26/21 12:55:41 AM.085: creating directory "BACKUP"
5/26/21 12:55:41 AM.086: creating directory "CLIPINF"
5/26/21 12:55:41 AM.101: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\CLIPINF\00000.clpi"
5/26/21 12:55:41 AM.106: creating directory "BDMV"
5/26/21 12:55:41 AM.107: creating directory "STREAM"
5/26/21 12:55:41 AM.122: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\STREAM\00001.m2ts"
5/26/21 12:55:41 AM.126: creating directory "BDMV"
5/26/21 12:55:41 AM.127: creating directory "PLAYLIST"
5/26/21 12:55:41 AM.142: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\PLAYLIST\00001.mpls"
5/26/21 12:55:41 AM.147: creating directory "BDMV"
5/26/21 12:55:41 AM.148: creating directory "BACKUP"
5/26/21 12:55:41 AM.150: creating directory "PLAYLIST"
5/26/21 12:55:41 AM.165: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\PLAYLIST\00001.mpls"
5/26/21 12:55:41 AM.169: creating directory "BDMV"
5/26/21 12:55:41 AM.170: creating directory "CLIPINF"
5/26/21 12:55:41 AM.185: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\CLIPINF\00001.clpi"
5/26/21 12:55:41 AM.189: creating directory "BDMV"
5/26/21 12:55:41 AM.191: creating directory "BACKUP"
5/26/21 12:55:41 AM.192: creating directory "CLIPINF"
5/26/21 12:55:41 AM.206: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\CLIPINF\00001.clpi"
5/26/21 12:55:41 AM.211: creating directory "BDMV"
5/26/21 12:55:41 AM.213: creating directory "STREAM"
5/26/21 12:55:41 AM.226: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\STREAM\00002.m2ts"
5/26/21 12:55:41 AM.232: creating directory "BDMV"
5/26/21 12:55:41 AM.233: creating directory "PLAYLIST"
5/26/21 12:55:41 AM.248: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\PLAYLIST\00002.mpls"
5/26/21 12:55:41 AM.253: creating directory "BDMV"
5/26/21 12:55:41 AM.254: creating directory "BACKUP"
5/26/21 12:55:41 AM.255: creating directory "PLAYLIST"
5/26/21 12:55:41 AM.269: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\PLAYLIST\00002.mpls"
5/26/21 12:55:41 AM.274: creating directory "BDMV"
5/26/21 12:55:41 AM.275: creating directory "CLIPINF"
5/26/21 12:55:41 AM.289: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\CLIPINF\00002.clpi"
5/26/21 12:55:41 AM.294: creating directory "BDMV"
5/26/21 12:55:41 AM.296: creating directory "BACKUP"
5/26/21 12:55:41 AM.297: creating directory "CLIPINF"
5/26/21 12:55:41 AM.310: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\CLIPINF\00002.clpi"
5/26/21 12:55:41 AM.315: creating directory "BDMV"
5/26/21 12:55:41 AM.316: creating directory "STREAM"
5/26/21 12:55:41 AM.330: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\STREAM\00003.m2ts"
5/26/21 12:55:41 AM.334: creating directory "BDMV"
5/26/21 12:55:41 AM.335: creating directory "PLAYLIST"
5/26/21 12:55:41 AM.354: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\PLAYLIST\00003.mpls"
5/26/21 12:55:41 AM.358: creating directory "BDMV"
5/26/21 12:55:41 AM.359: creating directory "BACKUP"
5/26/21 12:55:41 AM.360: creating directory "PLAYLIST"
5/26/21 12:55:41 AM.375: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\PLAYLIST\00003.mpls"
5/26/21 12:55:41 AM.380: creating directory "BDMV"
5/26/21 12:55:41 AM.381: creating directory "CLIPINF"
5/26/21 12:55:41 AM.394: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\CLIPINF\00003.clpi"
5/26/21 12:55:41 AM.399: creating directory "BDMV"
5/26/21 12:55:41 AM.400: creating directory "BACKUP"
5/26/21 12:55:41 AM.401: creating directory "CLIPINF"
5/26/21 12:55:41 AM.415: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\CLIPINF\00003.clpi"
5/26/21 12:55:41 AM.420: creating directory "BDMV"
5/26/21 12:55:41 AM.421: creating directory "STREAM"
5/26/21 12:55:41 AM.435: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\STREAM\00004.m2ts"
5/26/21 12:55:41 AM.440: creating directory "BDMV"
5/26/21 12:55:41 AM.441: creating directory "PLAYLIST"
5/26/21 12:55:41 AM.456: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\PLAYLIST\00004.mpls"
5/26/21 12:55:41 AM.460: creating directory "BDMV"
5/26/21 12:55:41 AM.461: creating directory "BACKUP"
5/26/21 12:55:41 AM.463: creating directory "PLAYLIST"
5/26/21 12:55:41 AM.476: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\PLAYLIST\00004.mpls"
5/26/21 12:55:41 AM.481: creating directory "BDMV"
5/26/21 12:55:41 AM.482: creating directory "CLIPINF"
5/26/21 12:55:41 AM.497: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\CLIPINF\00004.clpi"
5/26/21 12:55:41 AM.501: creating directory "BDMV"
5/26/21 12:55:41 AM.502: creating directory "BACKUP"
5/26/21 12:55:41 AM.503: creating directory "CLIPINF"
5/26/21 12:55:41 AM.518: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\CLIPINF\00004.clpi"
5/26/21 12:55:41 AM.522: creating directory "BDMV"
5/26/21 12:55:41 AM.523: creating directory "STREAM"
5/26/21 12:55:41 AM.537: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\STREAM\00005.m2ts"
5/26/21 12:55:41 AM.542: creating directory "BDMV"
5/26/21 12:55:41 AM.543: creating directory "PLAYLIST"
5/26/21 12:55:41 AM.558: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\PLAYLIST\00005.mpls"
5/26/21 12:55:41 AM.563: creating directory "BDMV"
5/26/21 12:55:41 AM.564: creating directory "BACKUP"
5/26/21 12:55:41 AM.565: creating directory "PLAYLIST"
5/26/21 12:55:41 AM.579: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\PLAYLIST\00005.mpls"
5/26/21 12:55:41 AM.584: creating directory "BDMV"
5/26/21 12:55:41 AM.585: creating directory "CLIPINF"
5/26/21 12:55:41 AM.599: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\CLIPINF\00005.clpi"
5/26/21 12:55:41 AM.604: creating directory "BDMV"
5/26/21 12:55:41 AM.605: creating directory "BACKUP"
5/26/21 12:55:41 AM.606: creating directory "CLIPINF"
5/26/21 12:55:41 AM.620: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\CLIPINF\00005.clpi"
5/26/21 12:55:41 AM.625: creating directory "BDMV"
5/26/21 12:55:41 AM.626: creating directory "STREAM"
5/26/21 12:55:41 AM.640: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\STREAM\00006.m2ts"
5/26/21 12:55:41 AM.645: creating directory "BDMV"
5/26/21 12:55:41 AM.647: creating directory "PLAYLIST"
5/26/21 12:55:41 AM.660: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\PLAYLIST\00006.mpls"
5/26/21 12:55:41 AM.665: creating directory "BDMV"
5/26/21 12:55:41 AM.666: creating directory "BACKUP"
5/26/21 12:55:41 AM.667: creating directory "PLAYLIST"
5/26/21 12:55:41 AM.681: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\PLAYLIST\00006.mpls"
5/26/21 12:55:41 AM.686: creating directory "BDMV"
5/26/21 12:55:41 AM.687: creating directory "CLIPINF"
5/26/21 12:55:41 AM.701: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\CLIPINF\00006.clpi"
5/26/21 12:55:41 AM.706: creating directory "BDMV"
5/26/21 12:55:41 AM.707: creating directory "BACKUP"
5/26/21 12:55:41 AM.708: creating directory "CLIPINF"
5/26/21 12:55:41 AM.723: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\CLIPINF\00006.clpi"
5/26/21 12:55:41 AM.732: creating directory "BDMV"
5/26/21 12:55:41 AM.733: creating directory "STREAM"
5/26/21 12:55:41 AM.748: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\STREAM\00007.m2ts"
5/26/21 12:55:41 AM.753: creating directory "BDMV"
5/26/21 12:55:41 AM.753: creating directory "PLAYLIST"
5/26/21 12:55:41 AM.768: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\PLAYLIST\00007.mpls"
5/26/21 12:55:41 AM.772: creating directory "BDMV"
5/26/21 12:55:41 AM.773: creating directory "BACKUP"
5/26/21 12:55:41 AM.774: creating directory "PLAYLIST"
5/26/21 12:55:41 AM.789: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\PLAYLIST\00007.mpls"
5/26/21 12:55:41 AM.793: creating directory "BDMV"
5/26/21 12:55:41 AM.794: creating directory "CLIPINF"
5/26/21 12:55:41 AM.809: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\CLIPINF\00007.clpi"
5/26/21 12:55:41 AM.814: creating directory "BDMV"
5/26/21 12:55:41 AM.815: creating directory "BACKUP"
5/26/21 12:55:41 AM.816: creating directory "CLIPINF"
5/26/21 12:55:41 AM.830: adding file "C:\Users\DougG\Documents\MAGIX\Movie Edit Pro 2016\Disc Images\BD Image Filename\BDMV\CLIPINF\00007.clpi"
5/26/21 12:55:41 AM.834: Step 11 done
5/26/21 12:55:41 AM.839: ------------ done ----------------
5/26/21 12:55:41 AM.840: Step 11 of 11
5/26/21 12:55:41 AM.847: ------------ BurnToDisc ----------------
5/26/21 12:55:41 AM.858: Used burn options:
simulation: off
DiscAtOnce: off
BurnOver: off
BurnProof: on
FormatDisc: off
ShortLeadOut: off
NoDefectMgmt: off
5/26/21 12:55:41 AM.859: Booktype: don't care
5/26/21 12:55:41 AM.863: setting write speed to 26976000 bytes/sec
5/26/21 12:55:41 AM.864: this equals 19.477257x DVD / 152.925171x CD Speed
5/26/21 12:55:41 AM.866: mounting volume on device...OK
5/26/21 12:55:41 AM.867: -- Volume mounted --
5/26/21 12:55:41 AM.867: -- Recording on "F: HL-DT-ST BD-RE WP50NB40" --
5/26/21 12:55:41 AM.868: -- Medium is "BD-R" --
5/26/21 12:55:41 AM.869: -- Manufacturer "VERBAT" --
5/26/21 12:55:41 AM.884: AVSDK Message - INFO: :Recording volume ...
5/26/21 12:55:41 AM.885: AVSDK Status - Begin operation Recording 11701248 sectors/frames
5/26/21 12:55:41 AM.890: AVSDK Message - INFO: :Recording -> writing data ...
5/26/21 12:55:42 AM.261: wrote LeadIn, start DataCopy
5/26/21 12:56:04 AM.856: AVSDK Message - ERROR: :Cannot write to disc -> Write error (SK/ASC/ASCQ 03/0C/00)
5/26/21 12:56:28 AM.905: AVSDK Message - ERROR: :Cannot re-open drive -> Required command option not supported by drive (SK/ASC/ASCQ 05/24/00)
5/26/21 12:56:28 AM.916: AVSDK Status - End operation Recording 11701248 sectors/frames
5/26/21 12:56:28 AM.927: AVSDK Message - INFO: :Recording failed due to write error on disc
5/26/21 12:56:28 AM.938: !!! AVSDK error: BurnToDisc() calling AvVolWriteToDisc(): 206 - write error occurred on disc !!!
5/26/21 12:56:28 AM.939: !!! DBK error in CBurnDevSupportPoint::BurnToDisc(): 224 - write error occurred on disc !!!
5/26/21 12:56:28 AM.940: ------------ done ----------------
5/26/21 12:56:28 AM.940: Step 11 done
5/26/21 12:56:28 AM.944: project burning failed
5/26/21 12:56:28 AM.949: !!! DBK error in CBurnDevSupport::BurnProject(): 224 - write error occurred on disc !!!
5/26/21 12:56:28 AM.951: !!! DBK error in BurnProject: 224 - write error occurred on disc !!!
Bump anyone? I have the same problem currently just with the Movie Edit Pro 2017 version.
4K UHD Blu Ray Remux to Blu Ray (regular) for burning
By Damirko1981 in forum Authoring (Blu-ray)Replies: 9Last Post: 9th Apr 2025, 20:04 -
Losslessly edit UHD 4K Blu-ray w/ Dolby TrueHD?
By ogrgkyle in forum EditingReplies: 23Last Post: 11th Feb 2021, 13:34 -
Rip & Edit Blu-ray to video @ 1:1 no compression
By houseroundfile in forum MacReplies: 9Last Post: 5th Feb 2021, 17:11 -
Computer power required to edit Blu-ray without re-encoding
By Daniel_BMS in forum EditingReplies: 0Last Post: 29th Nov 2016, 18:25 -
2016 Value Electronics HDTV Shootout - June 22-23, 2016
By lingyi in forum Latest Video NewsReplies: 4Last Post: 18th Jun 2016, 11:14
