So I just successfully burned a backup of some media I bought onto a Blu-Ray disc. I made menus and did all that fancy stuff in Adobe Encore CS6 and made sure it worked before I rendered out a .iso file. Then once I found out it worked I got the .iso and burned it onto a Blu-Ray disc in IMGBurn. Everything went smooth. I go to open my Blu-Ray on VLC Media Player and it works like a charm. But then I go and put it into my LG BP175 and it loads fine until I get to the main menu. I have two options on the Main Menu screen and none of them are highlighted, I try pressing the down and up arrows and I don't see anything getting highlighted. So I then just decide to press the "OK" button. That plays the first menu option which is a play-all button on my disc. I'd like to be able to highlight and select the other menu option, which if you are curious is an episode-selection button. Does anyone know what is going on? Do I need to give more information about anything? I'd like to be able to play this Blu-Ray on my actual Blu-Ray player as that's my main reason for making this. Thanks
EDIT: Thanks to a friend I figured out the solution. If you guys ever run into the issue, try pressing the side arrows a few times rather than the up and down arrows and it should hopefully pop up!
Results 1 to 1 of 1
Visio Blu Ray player vbr120 unable to read Blu ray discs
By juntjoo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 14th Sep 2020, 13:02 -
Can a Blu-ray player play Blu-ray video burned on a DVD?
By digicube in forum Blu-ray RippingReplies: 2Last Post: 16th Jan 2019, 02:11 -
Ripbot264 Convert UHD Blu-ray 4k to Blu-ray 1080p
By microhunt in forum DVD RippingReplies: 0Last Post: 23rd Dec 2018, 12:12 -
Leawo Blu-ray Player: Problems Playing Blu-Ray Discs
By devilcoelhodog in forum Software PlayingReplies: 11Last Post: 24th Mar 2017, 08:32 -
Blu Ray iso on a DVD...will it work on a Blu Ray player?
By DumdogsWorld in forum Newbie / General discussionsReplies: 5Last Post: 25th Nov 2016, 05:09
