I will have to capture again. I deleted it.
Also I figured out that I could take my original OBS capture and use Virtualdub to re-encode back into huffyuv. It created a huffyuv file that was marked correctly.
You are most certainly correct about tape quality. This one has mild tracking problems. I can capture the same tape and it will freeze at random points in different captures.
I wondered if there is some latency issue that OBS didn't have. Maybe I was just lucky before?
I am creating an ISO and hope to test an interlaced DVD tonight.
I will un another capture and post a sample afterwards.
Results 61 to 63 of 63
Thanks for the sample. As near as I can tell, the video itself has no interlacing information. The original AVI spec doesn't have such a flag. The video file doesn't have an ODLM2 extension that could be used to flag interlacing. And finally the huffyuv codec has no private interlacing information that I know of. It looks like MediaInfo just calls any huffyuv 2.1.1 video interlaced if it is over 288 lines tall. If you crop your video and save it as 288 lines or less MediaInfo report progressive. If you crop to frame height over 288 (for example 292) it will report interlaced. It doesn't matter if the content is truly interlaced or progressive. Also, if you use some of the other huffyuv variants (ffmpeg, ffdshow, huffyuvmt) MediaInfo will always report progressive.
Creating x264
By magnu in forum Video ConversionReplies: 16Last Post: 26th May 2018, 10:45 -
Creating a video with certain specs
By Run222 in forum MacReplies: 7Last Post: 21st Mar 2018, 18:04 -
creating watermark for video???
By kenny1999 in forum Newbie / General discussionsReplies: 5Last Post: 1st Jun 2017, 17:08 -
Creating an enhanced cd
By fokfokfok in forum Newbie / General discussionsReplies: 15Last Post: 26th May 2017, 22:05 -
Creating a new thread?
By ranger2001 in forum Newbie / General discussionsReplies: 1Last Post: 14th Aug 2016, 10:48
