In most of the video converters users can choose between two AAC codecs/encoders:
- (default) AAC (lav)
and
- Fraunhofer AAC
Is there a significant difference between them?
In particular I am interested if there is a negative impact on (later) keyframe-oriented cutting and on audio-video syncing
I'm guessing, but I think AAC (lav) is probably the native ffmpeg encoder. Of the freely available encoders, it's probably the lowest quality, although they're all quite good at decent bitrates.
Fraunhofer AAC is probably the encoder supplied with the last version of WinAMP. It should be quite good.
QAAC is considered to be one of the best, if not the best, AAC encoder. It uses the Apple itunes encoder. If you have itunes installed you can download and run QAAC. If you don't, you can download the full/offline itunes installer and extract the necessary files. There's no need to install itunes.
All lossy encoders use frames, so the audio has to be cut on an audio frame, but any decent muxing program would add an appropriate audio delay after removing an audio frame when cutting, assuming it's necessary. The length of an audio frame is quite small.
Lossy encoders also add padding to the beginning and end of the audio. Usually for AAC, information is saved to the MP4/M4A container so players can skip the padding (gapless playback). If that information is present, MKVToolNix will use it to remove the padding and/or automatically apply an audio delay to compensate so the AV sync remains exact.
QAAC is the only encoder (as far as I know) with an option to not pad the beginning of the audio with silence. The command line argument is --no-delay.
Here's a link for a version of foobar2000 I uploaded a while back.
foobar2000 portable (for audio encoding)
It's a portable version so you can just unzip and run it. It's ready to go for encoding with the freely available AAC encoders, and it comes with conversion and encoder presets for converting just about any format to any format. About the only thing you need to do is download and put ffmpeg in the encoders folder for decoding/encoding some audio types. The necessary files for encoding with QAAC are included. There's also conversion and DSP presets for downmixing and/or compression. It's a year or so old now, but everything runs on XP.
Some links
QAAC
I think the current makeportable2.cmd file for extracting the required files from the itunes installer is here, if you want to update the encoder to the latest version, or the 64 bit version, at some stage.Last edited by hello_hello; 28th May 2021 at 05:40.
Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview) -
So Fraunhofer AAC is better than AAC (lav)?
and should be used if available?
Is there any disadvantage for Fraunhofer AAC (e.g. when cutting and/or editing audio)?
Can I use both in MP4 video containers together with H.264 video codecs? -
aac files from youtube - what is the difference? (ffmpeg -i)
By Prototype v1.0 in forum AudioReplies: 7Last Post: 5th Aug 2019, 14:02 -
how can i encode aac codec like that
By enable in forum AudioReplies: 4Last Post: 14th Dec 2018, 06:02 -
Converting an AAC Mono file to AAC Stereo, higher audio bitrate?
By brightmademedia in forum AudioReplies: 2Last Post: 17th Jun 2017, 09:41 -
Handbrake without FDK-AAC, new FFMPEG AAC encoder viable alternative?
By jaggy in forum Video ConversionReplies: 15Last Post: 27th Apr 2017, 10:31 -
DTS to AAC using Nero AAC encoder command line.
By knightplex in forum AudioReplies: 25Last Post: 5th Nov 2016, 21:27
