  1. I installed MPCH on to my windows 10 laptop and it play videos.
    I Googled for a MPCH forum but it did not find any forum for this software.
    Has anyone found a forum for this software?
    In other media viewers you can see how much time has elapsed and how much time is left as it plays across along a progress bar.
    In MPCH, it seems you have to keep hovering the mouse over the progress bar to see how much time has elapsed and how much is left.
    Is there another way or a Media Player Classic - Forum I can post this to?
    Thank you!
    Feb 2006
    turn on OSD (on screen display) - https://sourceforge.net/p/mpcbe/tickets/612/
  3. I just pressed the letter "i" and it did nothing. I then held down Ctrl+Shift + i and that did nothing.
    Also, is there a keyboard shortcut (hotkey?) if you wish to watch the video in FF 1 second at a time or Rewind one second at a time?
    In some applications you just press the forward or arrow keys. That doesn't seem to work with MPHC.
    I typed that in the Search engine of the Source Fore but found nothing.
    Thanks.
  4. Kawaiiii
    May 2021
    Italy
    Thanks.
    I presume you're talking about MPC-HC (that stands for Media Player Classic - Home Cinema)..
    Anyway if you from the menu View click Options (default shortcut = O) you can then look under Player -> keys what are the current key assignment and eventually change/customize them. Don't remember if there's a function to go forward/back exactly by a second .. but there are 3 different amounts for the function "jump forward/backward".. small, medium, large...
    For having the status/info/playing bar displayed with current time/duration in windowed mode you have to activate : menu View -> Status (shortcut CTRL + 5)
    To have the controls constantly shown in full screen mode too you have to : menu View -> Options (shortcut O),then Playback -> Fullscreen and uncheck the option "hide controls in fullscreen"
  5. I noticed if you keep pressing the FF or Skipback buttons it will slow the video down more each time to press on those buttons to the point it will move forward/backward in very slo mo.
    But the hotkeys under Player are very helpful, too!
    Is there anyway to export them as a .csv or copy/paste that chart?
    I tried Ctrl/C, Ctrl/V and right clicking but that didn't do anything.
    Thank you!
  6. Originally Posted by eager to learn View Post
    Thank you!
    No that's not currently supported.
    Here's the the forum thread for mpc-hc: https://forum.doom9.org/showthread.php?t=175209&page=70
