Hi, i have a sony dvd/vcd/cd player, but i cant seem to play any vcds that i burn. I use Nero 5.5 to burn the vcds and i have tried CloneCD 3.3.4.1, but they still do not seem to work on my player. When i play it on computer its fine, but just doesnt work on my player. Is it because my player doesn't support it, or burner doesn't burn it right, or I'm burning it wrong with my softwares. I need help, thanks in advance. :)
I've been having the same problem with my Sony player, and I've been using VCDEasy. Anyone have any ideas on how to fix it or what the different problems could be?
What model number is your Sony DVD player, as if its like my friends Sony DVD player (DVP-NS 300) then it will only player some types of CDR's.
Shepo. -
you are using cd-rw discs right, not cd-r's ? and sooner or later you'll realize you should have bought a Pioneer as they play anything and any media.
One easy way to find out is to bring you home made VCD to Circuit City and try it on many different DVD players.
I would recommend to try on Pioneer 333/343/525.
If it works (most likely it will) then you know the answer.ktnwin - PATIENCE -
i was using cd-rs, ill try it with cd-rw if i can fit the movie and see what happens
I have a Panasonic A115U which is supposed to play VCD but to date it's a no show except for Ricoh CD-RW disks. It depends on media type and quality of the media. I also have an APEX 1200 which will play almost anything. You may have to experiment with media to get the right mix.
My Sony CD/DVD player (NS55P) would almost only play sony discs.
By valdes001 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 30th Jan 2011, 10:03 -
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
Cannot play Zone 1 disc on my Sony dvp-sr100 DVD player
By lea in forum DVD & Blu-ray PlayersReplies: 12Last Post: 23rd Apr 2010, 13:24 -
Can't play MP3s on my Sony DVP NS355 DVD player
By harrylentil in forum DVD & Blu-ray PlayersReplies: 4Last Post: 6th Aug 2009, 14:04 -
Would i be able to play a pal dvd with a sony blu ray player
By fceurich in forum DVD & Blu-ray PlayersReplies: 3Last Post: 7th Feb 2008, 09:47
