I have some tapes that cannot advance in the camcorder. I tried using a screwdriver to pull down the tab on the casing between the 2 spools. but even so the spools don't seem to rotate freely. I suspect the tape is sticking.
I can open it up but are there any guides to respooling? Is there any way to reduce the tape sticking?
Dried up mold can clog video heads, Be careful when playing back those tapes. There are a lot of creative ways of re-spooling tapes depends on your skills and tools available, Which ever method you use always use low speed, High speed high torque can break the tape. There are few useful videos on youtube.
Not gonna know until you pop it open. Take some photos as soon as you open it in case any clips fall out. They aren't much different than opening a VHS or 8MM tape, just smaller.
Smaller makes it different. I know, having worked on all of them manually many times.
Mini Dv tapes cloning in Windows
By Caltech in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 16th Jan 2021, 12:00 -
Problems with importing mini dv tapes
By fine0023 in forum MediaReplies: 4Last Post: 7th Jun 2020, 13:42 -
Transfer mini dv tapes to PC
By c-leigh in forum Capturing and VCRReplies: 2Last Post: 6th Apr 2020, 01:46 -
Need to Transfer Mini DV Tapes
By Jay4 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 24th Sep 2019, 21:48 -
Best way to transfer Mini DV tapes to the computer?
By kelemvor in forum Video ConversionReplies: 5Last Post: 29th Dec 2016, 13:11
