After LoadPlugin("C:\Path\to\LSMASHSource.dll") I received "Platform returned code 127".
Using 32 bit Windows Vista.
Using VDub2.
Results 31 to 35 of 35
Did you change the path to LSMASHSource.dll? You must use the path to where the dll is on your computer.
Then why didn't you say so? Why do you have to make it so hard to help you? PASTE THE FULL SCRIPT YOU ARE TRYING TO OPEN. ARE YOU USING 32 BIT OR 64 BIT VIRTUALDUB2?
Yes, that could be the point. Will check when current rendering with FFMpegSource2 is over, that is after 11 days (no joke), thanks.
Converting Blu-Ray YUV to RGB and back to YUV?
By killerteengohan in forum RestorationReplies: 17Last Post: 17th Mar 2020, 20:42 -
Help Converting YUV to RGB
By chris319 in forum Video ConversionReplies: 7Last Post: 24th Sep 2018, 18:51 -
RGB to YUV to RGB
By chris319 in forum ProgrammingReplies: 70Last Post: 20th Feb 2017, 16:49 -
ffmpeg/x264 RGB to YUV
By SameSelf in forum Video ConversionReplies: 40Last Post: 14th Nov 2016, 18:40 -
Converting Between 10-bit RGB and YUV and Back
By chris319 in forum Video ConversionReplies: 22Last Post: 8th Jul 2016, 23:53
