AVI Bit depth: 8 bits.
QTGMCing to MP4.
Should I keep 8 bits, not to switch to 10 bits looking for a bit better quality?
Thanks.
(.mp4 and .avi is a container format not video formats to that information is useless at best)
- 10bit processing usually is slower and power consuming to encode and decode.
- 10bit formats might be less supported by decoders.
- 10bit processing usually improves compression and lowers the chance of banding getting introduced through compression.
So, if the typical decoders for the video format you encode to supports 10bit, I would use 10bit encoding.users currently on my ignore list: deadrats, Stears555, marcorocchini
Is there a way to concatenate videos with different bit depth
By Felow in forum Newbie / General discussionsReplies: 15Last Post: 3rd Jan 2020, 09:55 -
Why the rippers usually change the original bit of depth (DTS Core)?
By Enrik in forum AudioReplies: 10Last Post: 26th Jul 2019, 17:53 -
PotPlayer downgrades DTS channels and bit depth?
By Zach_N85 in forum AudioReplies: 6Last Post: 19th Dec 2016, 14:08 -
24 Bits 5.1 FLAC Lower kHz than 16 Bits Stereo FLAC?
By draig-llofrudd in forum AudioReplies: 5Last Post: 17th Dec 2016, 08:03 -
MPC HC: 32-bit or 64-bit on Windows 7 64-bit
By flashandpan007 in forum Software PlayingReplies: 20Last Post: 22nd Jul 2016, 09:22
