  1. Hello all
    I got hands on a very badly deinterlaced video which seems to be at least encoded afterwards and possibly upscaled a bit.
    The video still shows deinterlacing lines and also ghosting and I tried dozens of things in avisynth (QTGMC, tdeint, Bobbing, ...) but the result is still bad. The main issue I think I have is that the interlaced lines seem to be too wide so I cannot separate fields and then there is also the ghosting problem.
    Anyone here who might have an idea how that video could be fixed?
    I attached a small sample.
    Many thanks for your help!
    Mar 2008
    I think you're out of luck. The video is essentially progressive, the two fields are identical, all those
    ugly blends and artifacts are "baked in"
  3. The blends are the main problem, since it's cartoon combing could probably be removed by down scaling height by 2 and after then resizing back to the original resolution,....
    users currently on my ignore list: deadrats, Stears555
  4. Ok thanks for the information. I guess I am out of luck then.
