  1. Hello. Can anyone please help me with my dilemma today? I'm trying to utilize ffmpeg to combine two TS files together into one without the need to re-encoding. I've sort of been experimenting a bit, all to no avail. I am literary going bold from tearing my hair out over this. I don't know whether its because I've entered the wrong commands in a bat file I've created, or maybe because the values differ slightly from one another? Can this be done with the TS format? Take a look below at the properties of the very files I'm trying to combine. Thanks!
    VIDEO 1
    Video
    Frame Width 1280
    Frame Height 720
    Data Rate 2972 kbps
    Total Bitrate 3067 kbps
    Frame Rate 30.00 frames/second
    Audio
    Bit rate 95 kbps
    Channels 2 (stereo)
    Audio Sample rate 48.000 kHz
    VIDEO 2
    Video
    Frame Width 1280
    Frame Height 720
    Data Rate 3059 kbps
    Total Bitrate 3159 kbps
    Audio
    Bit rate 100 kbps
    Channels 2 (stereo)
  2. - report any error messages.
    - try with avidemux.
  3. You could try with clever FFmpeg-GUI.
  4. Thank you for your suggestions.
    Thanks. I've utilized avidemux in the past for some projects. Never had to bind files with it though. I think is time for a reinstall.
    Wow. Just bind some files together. Really quick and simple. Thank you so much.
