Just info me is it dead in the water or a bit of hope is present, thanks.
Need to reduce huge motion blur or trails in an attached fragment.
To do something with green, since this error is greenish?
Video taken in environments too dark.
Attached fragment is after Neat Video and some great brightening script by themaster1,
that "motion blur" was present before all manipulations.
Did you use a deinterlacer on this, and keep every single frame?
It looks like too much framerate on playback. It's just playing back so fast. Just lower the framerate or convert to 25fps like it most likely should be, and see if you like it any better. I doubt that will 100% fix it, but I would assume that will help make it much more pleasing to watch.
As for the smearing, I don't think you will be able to get rid of that completely. Thats pretty bad.
fighting dark
By taigi in forum RestorationReplies: 11Last Post: 24th May 2021, 06:32 -
Attempting to remove ghosting (motion blur) after blend deinterlace
By antoniu200 in forum RestorationReplies: 9Last Post: 11th Mar 2021, 20:54 -
How to achieve frame-blending/motion blur?
By eko in forum Newbie / General discussionsReplies: 22Last Post: 29th Oct 2020, 09:36 -
Adding motion blur
By Duncgame in forum EditingReplies: 3Last Post: 21st May 2018, 16:35 -
motion blur during on 80's cartoon dvd's
By Acehit in forum Video ConversionReplies: 35Last Post: 30th Mar 2018, 14:09
