how to make one dvd that is over 4.7 gig into two dvd r? I have the latest version of nero. Thanks,
you read derrows or doom9s dvd rippings guides
www.vcdhelp.com/dvdripping.htm#dvd -
If its just the movie you want to rip and not the extras then here ya go
1: DO A FULL RIP OF DVD TO HARD DRIVE
2: OPEN INFOEDIT AND SELECT IFO OF MAIN MOVIE THEN SELECT VOB EXTRAS FROM TOP MENU AND THEN SELECT SPLIT TO 2 DVDRS. HAVE SELECTED REMOVE POPUPS, REMOVE MACROVISION, ADJUST VOB UNIT POINTERS & ADJUST AUDIO/SUBP POINT, CORRECT VOB UNIT, CORRECT IFO TABLES, AND SPLIT TO 2 DVD-RS, IF THE VOBIDS NEED STRIPPED ALSO SELECT STRIP VOBIDS. SELECT YOUR 2 DESTINATION DIRECTORIES AND PRESS OK CHOOSE THE SPLIT POINT AND VOBIDS (IF SELECTED) THEN LET INFOEDIT PROCESS THE VOBS.
3: WHEN THIS HAS COMPLETED YOU WILL HAVE VTS_01_0.BUP AND VTS_01_0.IFO PLUS A FEW VOB FILES VTS_01_1 VTS_01_2 ETC IN THE 2 FOLDERS.
4: OPEN INFOEDIT AGAIN AND SELECT THE NEW INFO FILE FROM YOUR FIRST SPLIT FOLDER THE SELECT VOB EXTRAS AND TICK BOXES CORRECT VOB UNIT, CORRECT IFO TABLES AND CREATE NEW VIDEO_TS.IFO & VTS_01_0.IFO. SELECT A DESTINATION FOLDER FOR THESE FILES YOU CAN USE THE SAME FOLDER BUT I PREFER TO USE ANOTHER FOLDER THEN COPY THE NEW FILES TO THE EXISTING FOLDER. WHEN THIS IS COMPLETED YOU WILL HAVE NEW VIDEO_TS.IFO, VIDEO_TS.BUP AND VTS_01.0.IFO AND VTS_01.0.BUP IF YOU PUT THESE INTO A NEW FOLDER COPY THEM TO THE ORIGINAL FOLDER AND REPLACE THE ORIGINALS.
5: NOW OPEN INFOEDIT AGAIN AND SELECT VTS_01_0.IFO FROM ONE OF THE SPLIT FOLDER AND SELECT GET VTS SECTORS AND KEEP PRESSING OK UNTIL IT FINISHES THEN CLOSE INFOEDIT.
6: OPEN INFOEDIT AGAIN AND NOW SELECT THE VIDEO_TS.IFO FROM THE SAME FOLDER AND SELECT GET VTS SECTORS SELECT YES WHEN PROMPTED AND OK UNTIL IT HAS FINISHED THEN EXIT, WHEN PROMPTED THAT YOU ARE EXITING WITHOUT SAVING CHANGES JUST SELECT YES AS CHANGES ARE SAVED AUTOMATICALLY.
7: REPEAT PROCESSES 4.5.6. FOR SECOND SPLIT FOLDER.
8: BEFORE BURNING MAKE SURE THE FOLDERS ARE NAMED VIDEO_TS. -
Thanks for the help, im now clear on what to do. i just am not sure of which programs to use? Do i use smart ripper and nero? Or are there other programs to use. I'd like to stay away from beta and freeware as possible. I dont mind purchasing programs.
why can't I make dvd w several half hour shows dvd architect/sonic-
By rr1 in forum Newbie / General discussionsReplies: 5Last Post: 14th May 2011, 13:28 -
Losing audio when i convert a 2 gig mp4 bluray to dvd with nero vision
By pkath123 in forum Video ConversionReplies: 0Last Post: 7th Nov 2010, 17:48 -
1080p Mkv To DVD-DL 8.5 Gig To Play On PS3 and Blu Ray
By Chevy434 in forum Authoring (Blu-ray)Replies: 5Last Post: 20th May 2010, 05:04 -
Best software (pref freeware) to make a music DVD that will play in a DVD
By Trollheart in forum AudioReplies: 10Last Post: 16th Jul 2009, 16:12 -
How many 4.7 Gig DVDs may fit into 500 gig HDD?
By Bronx in forum ComputerReplies: 11Last Post: 24th Apr 2008, 10:40
