Preview window look may differ from final avi capture.
The rule is that procamp should be set to avoid levels that your card cannot capture.
For example USB-Live 2 cannot capture illegal 0-16 levels, so if your tape/vcr/camera provides such range, you should tune brightness/contrast in procamp to stay inside 16-XXX range.
The info about range is given by histograms; you cold check them in real time (see jagabo post here https://forum.videohelp.com/threads/401225-Histogram-for-Amarec-TV) or make some experiment recording some portion of the tape showing the worst case.
Results 31 to 32 of 32
AmarecTV Won't Capture Audio from USB-Live2
By koberulz in forum Newbie / General discussionsReplies: 6Last Post: 31st Jul 2020, 18:32 -
Hauppauge Capture stuttering when using USB-Live2
By DPage in forum Capturing and VCRReplies: 14Last Post: 11th May 2020, 11:06 -
Hauppauge USB-Live2 not working in virtualdub
By BillyJeanB in forum Capturing and VCRReplies: 16Last Post: 24th Nov 2019, 04:34 -
USB-Live2 Brightness Issue (Video Example)
By JawsTDS in forum Capturing and VCRReplies: 8Last Post: 5th Jul 2019, 06:25 -
Bluray writer no longer sees BRs, still sees DVDs.
By cal_tony in forum DVD & Blu-ray WritersReplies: 14Last Post: 11th Jul 2018, 13:51
