    May 2021
    Lebanon
    I have an audio track in an .mkv file with these info:
    Format : E-AC-3 JOC
    Format/Info : Enhanced AC-3 with Joint Object Coding
    Commercial name : Dolby Digital Plus with Dolby Atmos
    Codec ID : A_EAC3
    I use MKVToolNix on mac and I couldn't find a way where I can make that track just E-AC3 and remove the Atmos components.
    Is there a way to do that? thanks.
    canada
    You can use audacity to convert to ac3 640kbps but not e- but others might have more info.I moved your thread to the mac forum where you can get more help.
  3. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Format : E-AC-3 JOC
    Codec ID : A_EAC3
    Unless your A/V equipment can play Dolby Atmos it will have no effect on your system. If you have access to a PC there is the Popcorn Audio Converter than can turn the track into a straight AC3 in situ.
  4. You could try with clever FFmpeg-GUI
