it doesn't work even with the new version, I recently deleted it because it only recognizes drm protected at all, try it too if you can download this video https://www.tvnz.co.nz/shows/the-bachelorette/episodes/s20-e1
Results 241 to 270 of 321
@killer30
[Attachment 72092 - Click to enlarge]
your file
https://www.transfernow.net/dl/20230627Thd75IZT -
the keys do not serve to reproduce, that it needs a help please.
PSSH:AAAAOHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABgiE M/WCirzBY5tkuyk2NVFmt9I49yVmwY=
[Attachment 72095 - Click to enlarge]Last edited by PABLITOMAO; 27th Jun 2023 at 17:22.
Guys I really need your help with this website. For example I tried this exact video. But I still can't get they key. Everytime I try, I encounter errors. Please someone show me what data you insert to get the keys for this video!
video:
https://jfc.org.il/en/movie/44195-2/
mpd:
https://d2148dkxdf27z.cloudfront.net/media/Owo5Jc4YorQ62/5c9bb795/stream.mpd
licence:
https://license.vdocipher.com/auth
PSSH (I found it inside mpd):
AAAAUnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADIiKnZkb2 NpcGhlcjpmNjY5ZjcyNDNiM2Y0NmZjYjAzZjBiMGY2NGI3OTAw ZUjj3JWbBg== -
So a very quick look at this shows that the PSSH needs to be generated from one of the KIDs in the MPD.
e.g. for the 1920 x 1080 it is cd7fe538-1444-5c1f-8525-707e0795daac
Also there appears to be a token in the licence call which you would need to incorporate (obviously making sure it hasnt expired)
lcsneil -
PSSH: AAAAOHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABgSEM1/5TgURFwfhSVwfgeV2qxI49yVmwY= from cd7fe538-1444-5c1f-8525-707e0795daac
I also got the same PSSH as A_n_g_e_l_a, using this site: https://tools.axinom.com/generators/PsshBox
I entered
System ID : EDEF8BA9-79D6-4ACE-A3C8-27DCD51D21ED
Key IDS (Widevine PSSH Data) : cd7fe538-1444-5c1f-8525-707e0795daac
Protection Scheme: cenc
But still I haven't got further. What do you mean by incorporating the token? As I understand when I copy my request to license to headers.py this request contains the token in data. -
I'm still struggling with this video.
I need a hint what is the right way to pass the license URL and maybe headers.
This is the basic license URL:
But there is a token. That is sent as data in Post.response (also if you look at the network in fact there are two post responses to license server with different tokens - one is shorter and the second is larger. Idk which one is the one that we need)
I don't know how to incorporate it correctly (I thought that it just should be included in headers.py as data but for some reason it doesn't work)
As a result every time I use l3.py script i get
{"code":2011,"message":"request unwrapping failed"} -
It doesn't work for me neither.
As there are two requests to license server I have a suspicion that this website uses 'privacy mode' that adds additional encryption when the license is requested.
On one of the forum's branches I found this explanation how to bypass it. But the explanation is too vague, maybe someone could elaborate it a little bit at least?
Explanation:
"You just need to define a byte array with 0x08, 0x04, send it as a payload using requests.post, then base64 encode the response and pass to WvDecrypt as cert_data_b64"Last edited by moonloop; 20th Jul 2023 at 12:29. Reason: wrote to instead of two
to moonloop, naim2007, A_n_g_e_l_a
I am also having same issue with remote chrome cdm
https://d1z78r8i505acl.cloudfront.net/media/KKzaKQeZNdsMq/ccae5a7f/stream.mpd
**** <cenc
ssh>AAAAUnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADIiKn Zkb2NpcGhlcjoxMDgxY2NlMTM2NWQ0YWYwYmQxOTlmNDUzMjNi Zjk0YUjj3JWbBg==</cenc
ssh>
https://license.vdocipher.com/auth (License url)
http://license.vdocipher.com (another License url)
How to get Keys ?
some hints will be very helpful. -
So from that MPD you need to convert the KID to get the correct PSSH. Note that in that MPD there are actually two KIDs depending on the quality of the stream.
So for example the higher bandwidth quality PSSH is AAAAOHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABgSEBcdvK yGuFGBkAe4eUoDmEpI49yVmwY=
Not the value you had.
lcsneil -
i tried extensions , script all github but could not get keys may be i am doing some thing wrong please guide me or drop some hint in right direction as i ask most people they just demand usd to help.
To get PSSH from Kid
Code:import base64 def get_pssh(keyId): array_of_bytes = bytearray( b'\x00\x00\x002pssh\x00\x00\x00\x00') array_of_bytes.extend(bytes.fromhex("edef8ba979d64acea3c827dcd51d21ed")) array_of_bytes.extend(b'\x00\x00\x00\x12\x12\x10') array_of_bytes.extend(bytes.fromhex( keyId.replace("-", ""))) return base64.b64encode(bytes.fromhex(array_of_bytes.hex())) kid = input("Please input KID in hex string: ") kid = kid.replace('-', '') assert len(kid) == 32 and not isinstance(kid, bytes), "wrong KID length" print("PSSH {}".format(get_pssh(kid).decode('utf-8'))) -
Or if you dont mind not being self sufficient then there is always https://tools.axinom.com/generators/PsshBox as has been stated many times before.
lcsneil -
I want to download mpd files from extrattvteam website, it has multi audio track when I use widevine guesser it says no keys found at this page
I want to how to download mpd files -
Mpd
https://bpprod3linear.akamaized.net/bpk-tv/irdeto_com_Channel_166/output/manifest.mpd
XML response
<?xml version="1.0" encoding="utf-8"?>
<!-- Created with Broadpeak BkS350 Origin Packager (version=1.12.1-28247) -->
<MPD xmlns
si="http://www.w3.org/2001/XMLSchema-instance" xmlns="urn:mpeg:dash
chema:mpd:2011" xmlns:cenc="urn:mpeg:cenc:2013" xsi
chemaLocation="urn:mpeg:dash
chema:mpd:2011 http://standards.iso.org/ittf/PubliclyAvailableStandards/MPEG-DASH_schema_files/DASH-MPD.xsd" type="dynamic" availabilityStartTime="1970-01-01T00:00:00Z" publishTime="2023-08-28T09:15:35.838102Z" minimumUpdatePeriod="PT8S" timeShiftBufferDepth="PT4H10M" maxSegmentDuration="PT8S" minBufferTime="PT30S" profiles="urn:mpeg:dash
rofile:isoff-live:2011,urn:com:dashif:dash264">
<Period id="1" start="PT0S">
<BaseURL>dash/</BaseURL>
<AdaptationSet id="1" group="1" contentType="audio" lang="eng" segmentAlignment="true" audioSamplingRate="48000" mimeType="audio/mp4" codecs="mp4a.40.2" startWithSAP="1">
<AudioChannelConfiguration schemeIdUri="urn:mpeg:dash:23003:3:audio_channel_c onfiguration:2011" value="2"/>
<!-- Common Encryption -->
<ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc" cenc:default_KID="2F27D053-D83D-5284-859C-DD8B26BB17E2">
</ContentProtection>
<!-- Widevine -->
<ContentProtection schemeIdUri="urn:uuid:EDEF8BA9-79D6-4ACE-A3C8-27DCD51D21ED">
<cenc
ssh>AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEC 8n0FPYPVKEhZzdiya7F+I=</cenc
ssh>
<!-- PlayReady -->
<ContentProtection schemeIdUri="urn:uuid:9A04F079-9840-4286-AB92-E65BE0885F95" value="MSPR 2.0">
<cenc
ssh>AAADQnBzc2gAAAAAmgTweZhAQoarkuZb4IhflQAAAyIiAw AAAQABABgDPABXAFIATQBIAEUAQQBEAEUAUgAgAHgAbQBsAG4A cwA9ACIAaAB0AHQAcAA6AC8ALwBzAGMAaABlAG0AYQBzAC4AbQ BpAGMAcgBvAHMAbwBmAHQALgBjAG8AbQAvAEQAUgBNAC8AMgAw ADAANwAvADAAMwAvAFAAbABhAHkAUgBlAGEAZAB5AEgAZQBhAG QAZQByACIAIAB2AGUAcgBzAGkAbwBuAD0AIgA0AC4AMAAuADAA LgAwACIAPgA8AEQAQQBUAEEAPgA8AFAAUgBPAFQARQBDAFQASQ BOAEYATwA+ADwASwBFAFkATABFAE4APgAxADYAPAAvAEsARQBZ AEwARQBOAD4APABBAEwARwBJAEQAPgBBAEUAUwBDAFQAUgA8AC 8AQQBMAEcASQBEAD4APAAvAFAAUgBPAFQARQBDAFQASQBOAEYA TwA+ADwASwBJAEQAPgBVADkAQQBuAEwAegAzAFkAaABGAEsARg BuAE4AMgBMAEoAcgBzAFgANABnAD0APQA8AC8ASwBJAEQAPgA8 AEMASABFAEMASwBTAFUATQA+ACsAYQBGAFcAYwAwAGgATgBNAH YAQQA9ADwALwBDAEgARQBDAEsAUwBVAE0APgA8AEwAQQBfAFUA UgBMAD4AaAB0AHQAcABzADoALwAvAHQAYQB0AGEAcABsAGEAeQ AuAGwAaQB2AGUALgBvAHQAdAAuAGkAcgBkAGUAdABvAC4AYwBv AG0ALwBwAGwAYQB5AHIAZQBhAGQAeQAvAHIAaQBnAGgAdABzAG 0AYQBuAGEAZwBlAHIALgBhAHMAbQB4AD8AQwByAG0ASQBkAD0A dABhAHQAYQBzAGsAeQAmAGEAbQBwADsAQQBjAGMAbwB1AG4AdA BJAGQAPQB0AGEAdABhAHMAawB5ACYAYQBtAHAAOwBjAG8AbgB0 AGUAbgB0AEkAZAA9ADQAMAAwADAAMAAwADEAMQA5ADwALwBMAE EAXwBVAFIATAA+ADwALwBEAEEAVABBAD4APAAvAFcAUgBNAEgA RQBBAEQARQBSAD4A</cenc
ssh>
<Role schemeIdUri="urn:mpeg:dash:role:2011" value="main"/>
<Representation id="audio_94482_eng=94000" bandwidth="94000">
<SegmentTemplate timescale="48000" initialization="Disney_Channel-$RepresentationID$.dash" media="Disney_Channel-$RepresentationID$-$Number$.m4s" startNumber="211649892">
<SegmentTimeline><S t="81273558144000" d="384000" r="1874"/></SegmentTimeline></SegmentTemplate></Representation>
</AdaptationSet>
<AdaptationSet id="2" group="1" contentType="audio" lang="tam" segmentAlignment="true" audioSamplingRate="48000" mimeType="audio/mp4" codecs="mp4a.40.2" startWithSAP="1">
<!-- Widevine -->
<cenc
ssh>
<!-- PlayReady -->
<cenc
ssh>
<Representation id="audio_94486_tam=94000" bandwidth="94000">
</AdaptationSet>
<AdaptationSet id="3" group="1" contentType="audio" lang="tel" segmentAlignment="true" audioSamplingRate="48000" mimeType="audio/mp4" codecs="mp4a.40.2" startWithSAP="1">
<!-- Widevine -->
<cenc
ssh>
<!-- PlayReady -->
<cenc
ssh>
<Representation id="audio_94490_tel=94000" bandwidth="94000">
</AdaptationSet>
<AdaptationSet id="4" group="1" contentType="audio" lang="hin" segmentAlignment="true" audioSamplingRate="48000" mimeType="audio/mp4" codecs="mp4a.40.2" startWithSAP="1">
<!-- Widevine -->
<cenc
ssh>
<!-- PlayReady -->
<cenc
ssh>
<Representation id="audio_94494_hin=94000" bandwidth="94000">
</AdaptationSet>
<AdaptationSet id="5" group="2" contentType="video" par="4:3" minBandwidth="226400" maxBandwidth="1297600" maxWidth="854" maxHeight="640" segmentAlignment="true" sar="3:4" frameRate="25" mimeType="video/mp4" codecs="avc1.4D401E" startWithSAP="1">
<!-- Widevine -->
<cenc
ssh>
<!-- PlayReady -->
<cenc
ssh>
<Representation id="video=226400" bandwidth="226400" width="320" height="180" scanType="progressive">
<SegmentTemplate timescale="600" initialization="Disney_Channel-$RepresentationID$.dash" media="Disney_Channel-$RepresentationID$-$Number$.m4s" startNumber="211649892">
<SegmentTimeline><S t="1015919476800" d="4800" r="1874"/></SegmentTimeline></SegmentTemplate></Representation>
<Representation id="video=457600" bandwidth="457600" width="480" height="270" scanType="progressive">
<Representation id="video=877600" bandwidth="877600" width="640" height="360" scanType="progressive">
<Representation id="video=1297600" bandwidth="1297600" width="854" height="480" scanType="progressive">
</AdaptationSet>
</Period>
<UTCTiming schemeIdUri="urn:mpeg:dash:utc:http-iso:2014" value="https://time.akamai.com/?iso"/>
</MPD>
How to find the Pssh, key and licence url -
Look, this is the 3rd time I'm telling you to read the sticky threads.
Even if someone provides you with a key, you still wouldn't know what to do with it.
Read this first:
https://forum.videohelp.com/threads/404994-Decryption-and-the-Temple-of-Doom -
Hi,
I have an MPD which is protected:
- I have the pssh key
- I have the license server url something in the form of: https://xt.irdeto.com/licenseServer/widevine/v1/x/license?contentId=x-123-123456&ls_session=
I can download the audio and the video file but they need decryption
I am not sure if ls_session is needed.
I tried to register to getwvkeys.cc but invites are paused for the moment. Can anybody advice how to get the key?Last edited by Assasin13; 30th Aug 2023 at 14:25.
Hi @Karoolus,
License: https://antenna-plus.live.ott.irdeto.com/licenseServer/widevine/v1/antenna-plus/license
PSSH: AAAAOHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABgSEJz3WP 6gJUSIpK+uyFQxPkhI88aJmwY=
Let me know if you need the parameters from the headers. License server is the same but key changes with each mpd.
Download encrypted video via DRM protected MPD manifest
By Beta2k in forum Video Streaming DownloadingReplies: 19Last Post: 15th Jan 2024, 11:47 -
mpd protected with DRM?
By chisdchisdq in forum Video Streaming DownloadingReplies: 21Last Post: 24th Mar 2022, 23:14 -
How to download mpd stream (DRM protected)?
By bodasaud in forum Video Streaming DownloadingReplies: 5Last Post: 3rd Feb 2021, 08:41 -
Downloading mpd stream (DRM protected?)
By odyssey1234 in forum Video Streaming DownloadingReplies: 8Last Post: 14th Aug 2019, 22:26 -
Impossible Website: MPD / Fragmented Video / DRM Protected - Need Help!
By dynrte in forum Video Streaming DownloadingReplies: 1Last Post: 3rd Sep 2018, 00:03
