Because people go to youtube to watch the contents not the frame rate, Besides people tend to nit and pick on higher quality videos HD and 4K, low resolution and low quality videos like in your sample are hard to notice the quality differences.
Just a tip about youtube, upscale to 1440x1080 if you want less compression artifacts, It is the lowest resolution that youtube considers your video as SD and apply a higher tier compression.
Results 61 to 72 of 72
But the source is 25 fps, so wouldn't it be better to keep it at 480? to save another encode. YouTube strips out the dupe frames, so the motion should be identical. I say "should", because the dupe frames do have slight differences, due to jitter on the tape. I'm not sure if that makes a perceptible difference to the motion once they're removed, I'm not noticing it in this samples.
https://youtu.be/fAxE2jn5AD8 upscaled 720@50 fps
https://youtu.be/ubG-ACFoCnk 480@25 fps
Could you just do a quick check to see if you think motion is better in 50 fps on the YT samples? looks about the same to me. Apologies for any ads, already had a complaint about that, but the music will trigger them, not much I can do. The ad revenue goes to the music licensor, not me.
Although I've been thinking about getting a better device to do this properly, maybe going back and re-doing some of my older VHS transfers too. As I don't really want these to be crap, I spent a long time recording them back in the day.
What would be a good product that would give better results? I'm prepared to splash out a little bit. Could I get a suitable, semi-decent device for this task, for say around £100-150? -
Yes, we are on the same page as that's more or less what I've been saying.
OK thanks, but that would require an extra encode, something I'm always wary of, perhaps that's my audio background kicking in, as more than one lossy encode is a big no-no in that field. Would the reduction of compression artifacts be more beneficial than the quality loss from the encode? -
You don't necessarily re-encode or encode in the first place, Take your lossless capture file, resize it to 1440x1080 and upload to youtube, let youtube encode it for you. That's how I upload my captures to youtube.
So resizing doesn't re-encode or cause any quality loss? That surprises me, as I thought it would, seeing as it's taking the source and changing it. Bear in mind that I'm unable to record losslessly at the moment, plus I've always been led to believe that it's a huge waste of space for projects like mine.
You guys have actually got me thinking about doing this right though. See my earlier post about wanting to get a new device, do you have any recommendations? -
The source isn't 25 fps. PAL VHS is 50 fields per second. Every one of those fields can be from a different point in time. Your 50p cap from VirtualDub has mostly 2 frames (originally fields) per source frame but in many places are are 3 fields per source frame. I even saw a few places where there were 4 frames per source frame. This is probably because the game console was usually generating frames at 25p but sometimes slowed to 16.7p (3 fields) or even 12.5p (4 fields).
The 720p50 youtube video is clearly smoother than the 25p versions. Watch the motion of the buildings and other things in the background. There are very few obvious jerks in the 50p video. Many more in the 25p video. -
Thanks for the info, I knew there were 50 fields but I wasn't aware they would show separate points of time, the way I understood interlacing is that two combine together, which gives 25 points, but bear in mind my technical knowledge in this field is limited, which is why I'm here. So because the game is running at an uneven framerate, removing those frames will cause jerk? I think I understand. Am I right in thinking that it's the 3 field sections that would cause it, not the 4 field sections?
This may be moot now though, did you see the part about wanting to re-do this with a better device? do you have any recommendations? -
De-interlacing, resizing incur loss just like encoding but doing it on lossless files yields better results than doing it on an already encoded files.
I've been researching a new device and articles like this crop up, https://vhsconverters.com/7-video-capture-devices-tested-on-windows-10/
The guy is testing everything on OBS, this is why people like me make mistakes, we see articles like that and just assume that's the "done" thing. -
And I would not touch the majority of those products with a barge-pole.
'Easycap' seems to be this guy's 'fetish' or 'easycrap' as they are known around here - the device you have is likely to be one of their 'cousins'. The only one that had some credibility was the EZcap116 and even that has been pirated.
I thought with the small number of tapes you had you were not going to think about other hardware - unless you plan on redoing all the others as well.
The only device I can rec is a Hauppauge USB-Live2. Two are listed on Amazon. One is shipped from the US. The UK sourced one is doubtful to me. My own Amazon page says I bought this in 2013 and indeed I did by a USB-Live2 at that time. However the box suggests it includes Arcsoft software. Hauppauge does NOT come with any other software other than WinTV which you would not use - a driver is available for download.
A 'proper' USB-Live2 can be acquired from Amazon.fr . But do read the posts in this sub-forum since they will mention other products fully compatable with Win10. -
Thanks, yes I'm seriously thinking about re-doing some.
I've actually been doing this for years, have hundreds of tapes. Before, I was on a Mac set up with a different device, and my software was configured by a video professional. When I switched to Windows a couple of years ago, I had to change my set up, so everything I've done since then has been with OBS.
I had a similar device to the one I've got now, but it had a fault with the audio, so I got my current one to mop up the last few tapes. I'm prepared to re-do every tape I captured since migrating to Windows, I'm happy with the ones I did on the Mac.
Ghosting in the captured footage
By retractOffer in forum Capturing and VCRReplies: 10Last Post: 30th Aug 2020, 09:19 -
Is a UK PAL video tape compatible with a continental Europe PAL VHS/S-VHS p
By arjaydavis in forum Capturing and VCRReplies: 7Last Post: 21st May 2019, 04:38 -
Would you double the FPS for interlaced footage
By Sir_Loin in forum Video ConversionReplies: 4Last Post: 4th May 2018, 21:03 -
What capture program lets you hear the footage as it is being captured?
By BirdDaddie in forum Capturing and VCRReplies: 3Last Post: 17th Jan 2018, 12:58 -
How to insert appropriate timecode in 120 or 300 fps footage?
By Heliooos in forum EditingReplies: 5Last Post: 14th May 2017, 09:48
