Runing QTGMC TFF, but it makes BFF (twitching video). Paste'ing .avs and read of MediaInfo of video file. Help?:
SetFilterMTMode ("QTGMC", 2)
FFMPEGSource2("videofile.avi", atrack=1)
AssumeTFF()
QTGMC(preset="Placebo")
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, ReFrames: 2 frames
Format settings, GOP : M=3, N=12
Codec ID : 27
Duration : 11 min 23 s
Bit rate mode: Variable
Bit rate : 22.7 Mb/s
Width: 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth: 8 bits
Scan type: Interlaced
Scan type, store method : Separated fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.438
Stream size : 1.81 GiB (95%)
Results 1 to 17 of 17
Have you tried by commenting out or removing the 'AssumeTFF' line?
#AssumeTFF()
QTGMC(preset="Placebo") -
Without an explicit AssumeTFF() or AssumeBFF(), AviSynth will receive a field order from the used source filter. This may be correct if the source filter can identify a field order from flags in the contained video stream. Or it assumes any (like AviSource assuming BFF because DV in AVI is quite the only video format which almost certainly uses BFF)...
May have something to do with the interlaced mp4/AVC. Seems to cause a lot of problems,
perhaps the OP should switch to LWLlibavVideoSource -
aud = LWLibavAudioSource("video.ext") vid = LWLibavVideoSource("video.ext") AudioDub(vid,aud)
davexnet, poisondeathray and manono, LigH.de, you are collecting good karma, thanks.
That's not a fault of LwLibav*Source vs. LSMASH*Source. The former creates an index first (which takes additional time only once, so the estimation is wrong in the beginning), the latter relies on an index chunk in the MP4 file. But the rest of the filtering works identically.
Preset "Placebo" is nonsense for QTGMC. That's a certain waste of time. Try a sane preset. -
@LigH.de, I'm about to try possibly, but
maybe there are some other solution for this process?
LWLibavAudioSource and LWLibavVideoSource takes about 50 days to render now,
index was probably created already during last week of processing.
BTW, before that I used same QTGMC settings with FFMPEGSource2 and everything was much quicker. With no sound thou. -
That sounds very improbable. We may need to see a complete MediaInfo analysis (not only the Video chapter).
Also compare to a script with QTGMC commented out. Best run it in AVSMeter (or AVSMeter64, the same bitness as your encoder). I see no reason for such a long processing time, except an excess of parallel threads and memory consumption, so your system may be busy all the time swapping from RAM to disk and back?!
If you have many CPU cores, QTGMC may try to assign a lot of filtering threads on its own, especially in slowest presets, so it may be a good advice to limit Threads and even more EDIThreads. Search for more advices with this keyword... -
Complete MediaInfo analysis:
General
Complete name : F:\00001.MTS
Format : BDAV
Format/Info : Blu-ray Video
File size : 1.91 GiB
Overall bit rate : 23.9 Mb/s
Maximum Overall bit rate : 24.0 Mb/s
Recorded date : 2018-03-31 20:58:55+01:00
Writing application : Canon
Video
Menu ID : 1 (0x1)
Format : AVC
Format settings, Reference frames : 2 frames
Codec ID : 27
Bit rate mode : Variable
Width : 1 920 pixels
Color space : YUV
Bit depth : 8 bits
Scan type : Interlaced
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : 129
Bit rate mode : Constant
Bit rate : 256 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Delay relative to video : 32 ms
Stream size : 20.9 MiB (1%)
Service kind : Complete Main -
So your "videofile.avi" is in fact an MPEG Transport Stream? "Writing application : Canon" even suggests it may have come from an AVCHD camcorder. The stereo AC3 audio seems to confirm this guess.
Well, LSMASH Works (LwLibavVideoSource) should not have issues handling the video track. And the AC3 audio track should not be processed through AviSynth, you better demultiplex it and remultiplex it into your copy without a different encoding. So you can reduce your AviSynth script to something like:
Code:SetFilterMTMode("QTGMC", 2) LwLibavVideoSource("F:\00001.MTS") #AssumeTFF() QTGMC(Preset="Slow", EdiThreads=2) Prefetch(4)
Thanks. What could be the best way to demultiplex and remultiplex audio with this video?
Yes, all that was taken with Canon Legria HFG25 camera.
I have a question about your use of "#" sign before AssumeTFF() in an example of script provided at #14.
Is this not a sign of comment only?
Or should it be with a space after it if this is a comment?
Thanks.
Qtgmc-GUI. A simple encoder for your Qtgmc scripts.
By ProWo in forum Video ConversionReplies: 17Last Post: 4th Mar 2023, 02:01 -
Forcing TFF / BFF encoding with ffmpeg x.264
By Sharc in forum Newbie / General discussionsReplies: 2Last Post: 9th May 2020, 05:08 -
how to set scan order tff bff in mencoder?
By loriyipo in forum Newbie / General discussionsReplies: 0Last Post: 1st Nov 2019, 23:42 -
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 10th Jan 2017, 04:40 -
Blu-Ray Disc with Separated ass subs?
By Patapin in forum SubtitleReplies: 2Last Post: 14th Nov 2016, 04:41
