Hi. I am able to connect to a mpd server with ffmpeg using the correct header.
Now I am connected I am getting this error, over and over...
Does anyone know what this means?Code:[http @ 00000285f73f2780] HTTP error 400 Bad Request [dash @ 00000285f73db400] Failed to open fragment of playlist Failed to parse format-tag beginning with %08x$.m4s. Expected either a closing '$' character or a format-string like '%0[width]d', where width must be a single digit
Here is the command I am using
I have tried adding the -re option, but that didn't do anything.Code:ffmpeg -headers "Host: *hidden*" -i "*hidden*.mpd" -c copy -f mpegts pipe:
Any help is apreciated,
Chris
				Results 1 to 11 of 11
	Here is the site https://freefeds.com/video/67196/Discovery-Channel:US-TV-Channels.html
 Maybe it is "garbage" but I am having success with other sites that use m3u links with a similar command.
 I am not actually trying to download streams in the regular sense... I have created a little python app that finds the source stream on a web page and then streams back the video.
 Thanks.
 EDIT: It doesn't have to be with ffmpeg, but it would need to be with a command line utility that is available on linux and capeable of piping the output.Last edited by Chris91; 17th May 2021 at 19:15.
	If I run with debugging enabled I can see this...
 Surely the "$Number%08x$" part is incorrect? Shouldn't that be, for example...Code:[http @ 000001fb898f2500] HTTP error 400 Bad Request [dash @ 000001fb898db4c0] Failed to open fragment of playlist [dash @ 000001fb898db4c0] old fragment: cur[3326] min[6490] max[6490] Failed to parse format-tag beginning with %08x$.m4s. Expected either a closing '$' character or a format-string like '%0[width]d', where width must be a single digit [dash @ 000001fb898db4c0] DASH request for url 'http://p-cdn3-807-cg14-linear-cbd46b77.movetv.com/15807/live/DISC/1f818bdeb7b911eb92c60025b5471217/video/vid06/$Number%08x$.m4s', offset 0 [http @ 000001fb898f2500] Setting default whitelist 'http,https,tls,rtp,tcp,udp,crypto,httpproxy,data' [tcp @ 000001fb89b08340] Original list of addresses: [tcp @ 000001fb89b08340] Address 8.238.4.252 port 80 [tcp @ 000001fb89b08340] Address 8.238.4.124 port 80 [tcp @ 000001fb89b08340] Address 8.238.57.124 port 80 [tcp @ 000001fb89b08340] Interleaved list of addresses: [tcp @ 000001fb89b08340] Address 8.238.4.252 port 80 [tcp @ 000001fb89b08340] Address 8.238.4.124 port 80 [tcp @ 000001fb89b08340] Address 8.238.57.124 port 80 [tcp @ 000001fb89b08340] Starting connection attempt to 8.238.4.252 port 80 [tcp @ 000001fb89b08340] Successfully connected to 8.238.4.252 port 80 [http @ 000001fb898f2500] request: GET /15807/live/DISC/1f818bdeb7b911eb92c60025b5471217/video/vid06/$Number%08x$.m4s HTTP/1.1 User-Agent: Lavf/59.0.101 Accept: */* Connection: close Icy-MetaData: 1 Host: p-cdn3-1-606-cg15-linear-cbd46b77.movetv.com
 ?Code:https://p-cdn3-1-606-cg15-linear-cbd46b77.movetv.com/15807/live/DISC/1f818bdeb7b911eb92c60025b5471217/video/vid06/000019f3.m4s
	No. License url is only for realtime playback in a browser using dash.js , to play a file locally on e.g. desktop,you will need to obtain decryption key.
 Manifest:
 Key:Code:https://p-cdn3-1-606-cg15-linear-cbd46b77.movetv.com/clipslist/1102/20210524T060000Z/20210524T090000Z.mpd
 This is for local play/download thoCode:1810778124fe80e41f50a47fe161881b Last edited by Sviests; 24th May 2021 at 06:49.
  Help with MPDBy dzigelbaum in forum Video Streaming DownloadingReplies: 8Last Post: 18th Mar 2021, 05:05
  Is it possible to download dash mpd and convert into mp4 using ffmpeg?By MonikaChen in forum Video Streaming DownloadingReplies: 4Last Post: 16th Feb 2021, 10:09
  How to download this MPD?By jdanielw in forum Video Streaming DownloadingReplies: 2Last Post: 14th Feb 2021, 05:55
  Download this mpd... helpBy leoglez29 in forum Video Streaming DownloadingReplies: 4Last Post: 17th Jul 2020, 23:25
  ffmpeg cannot download mpd videoBy jcrayquaza in forum Video Streaming DownloadingReplies: 5Last Post: 26th Jun 2019, 12:22
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
