I used the guide for making a MiniDVD on this site. The only authoring software I have is Ulead movie factory. When I load the mpeg into movie factory it says audio format not supported.
Does another authoring software support AC3 audio.
Cheers
SpruceUp supports Dolby Digital audio.
But don't try to feed it a multiplexed MPEG file. You will need a separate .M2V video file with a matching .AC3 audio file in the same directory. Load the .m2v file and it will find the matching .AC3 file .
Ulead DVD Movie Factory 6 Plus
By Ragamuffin in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 12:22 -
Problems with Ulead Movie Factory
By merkuria_lyn in forum Authoring (DVD)Replies: 4Last Post: 25th Oct 2007, 13:12 -
Ulead Movie Factory 6 plus
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 02:20 -
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 07:14 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 18:20
