I'm trying to replace Bink video files in an original Xbox game because they weren't de-interlaced. However, I can't get them to play sound because they have a strange sound structure. All of them have standard Bink video, but they have 7 audio tracks marked as "old format" which has zero documentation as far as I can tell:
https://imgur.com/a/p5Z6sEQ
Using the "Mix in Audio" option within RAD Video Tools, I'm able to create de-interlaced versions with an identical structure, minus the "old format" tag:
https://imgur.com/a/xVIoH0s
Since the resulting video doesn't have "old format" audio, it's completely silent ingame. The video does play and I can tell it's no longer interlaced. I need one of the following:
1. A way to de-interlace Bink video files without converting to or from any other formats, and while not touching audio at all, preserving the original "old format" audio structure
2. A way to use the "Mix in Audio" option to add audio as "old format".
Due to there being practically no Bink documentation besides their short basic FAQ and the download link to the tools, as well as Bink never making their own official support forums, I can't figure out what to do. Am I out of luck? Surely after all these years of Bink being public, someone knows a way to do what I'm trying to do.
Did you have any luck?
this thread talks about using older version(s) of Rad Tools
https://forum.xentax.com/viewtopic.php?t=16180
https://drive.google.com/drive/folders/1AbNq_chm8rOj-o4WTjAUS5kcgld8_jsF -
Someone in another community solved it for me - if you set audio compression to 100, it'll be added as "old format", and with that I've de-interlaced all of the Bink videos I needed to. Apparently this is undocumented and older versions of RAD don't feature audio compression. I wonder how he found this, it states 99 is the maximum amount of audio compression.
Help with de-interlacing a video.
By Parhelion in forum Newbie / General discussionsReplies: 8Last Post: 19th Sep 2020, 17:35 -
Interlacing on video playback.
By Dencorub in forum Software PlayingReplies: 2Last Post: 30th Jan 2019, 08:59 -
De-interlacing video
By CarloJ63 in forum Newbie / General discussionsReplies: 5Last Post: 4th Oct 2018, 10:29 -
Video artifacts - De-interlacing.
By shans in forum Video ConversionReplies: 20Last Post: 22nd Sep 2018, 09:50 -
Keep Interlacing while processing a video
By Marcoh_ in forum RestorationReplies: 10Last Post: 25th Jul 2016, 18:03
