Ok I have wasted many CD's and it still won't work. What i'm trying to do is make a Video CD. I have made a small show in FlyVCD and it saved as an MPEG. From there I went to Roxio Easy CD Creator and that converted it into a VCD file and burned it all at the same time using the Wizard. I put it into my DVD Player and NOTHING........ What is going on?? Yes my DVD does read Video CD's. It does not read JPEG's. So I knew to make it a Video CD instead. Can someone help me out here please?
Vwman--Stephen
Try burning with nero also burn with a cdrw so you can use over and over during your trial and error periods.
To be honest I have nero and I hate it. It should work in Easy CD Creator. I'm just wondering if somewhere down the line i'm messing up somewhere.
Ok here's what I found out. The ones I did burn worked on my fathers DVD. but not mine???? Mine does say it supports Video CD. But it didnt' work. any ideas?
does your player maybe only like CDRW's? I know that's a problem with some players. or, it might be picky about which brand of CDR's it will and won't read. some players are very testy about that kind of stuff.Originally Posted by Vwman
Mov to mp4 won't work
By Klagar in forum Video ConversionReplies: 1Last Post: 15th Dec 2010, 12:07 -
Rip subtitles - won´t work.....help
By manutd in forum SubtitleReplies: 2Last Post: 9th Nov 2008, 17:24 -
cd drive rw won't work
By sue1951 in forum ComputerReplies: 6Last Post: 27th Aug 2007, 14:39 -
ffmpegX 0.0.9x r2 just won't work under X.3.9 ?
By Jose Hidalgo in forum ffmpegX general discussionReplies: 1Last Post: 16th Jul 2007, 09:37 -
Autoplay on PC won't work now
By gwoiler in forum Software PlayingReplies: 3Last Post: 31st May 2007, 16:36
