I am trying to mux a mpv, mpa, and ogt (overlay graphic text) files together. I can combine the mpv and mpa fine. I can combine the mpv and ogt (which I generated in the ogteditor) fine. But when I try to combine all three I get an error. Have any of you ever added subtitles this way? Is there a way to add the mpa component to the mps which is generated from the mux of mpv and ogt? I'm also thinking that this could be a problem with the "version" of I-author I have. I'd really appreaciate any help or any suggestions on subtitling and/or I-author use.
Thanks a million![]()
Use 100% compliant SVCD streams.
If bitrate exdeed 2700 kb/s (total) stupid I-author crash.
How to author a dvd from several xvid movies without sync problems
By rickywh in forum Authoring (DVD)Replies: 2Last Post: 8th Apr 2010, 15:02 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 20:33 -
Problems when I try to add subtles in my video on TMPG DVD Author 3
By ihmcjacky in forum Authoring (DVD)Replies: 4Last Post: 22nd Mar 2008, 02:24 -
TMPGenc DVD Author 3 Sound Problems
By wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 17:00 -
Problems with TMPGEnc DVD Author 3 and multiple AVI files
By cadkins in forum Authoring (DVD)Replies: 6Last Post: 9th May 2007, 15:37
