Hi. First, I'm not sure "crop" is the right word. I want to keep only the first portion of a video and dump the rest. I also want to process many files all at once. For example, I might have a folder with 50 videos of different lengths. Those that are less than a minute would remain untouched but for all the rest I only want the first 60 seconds. So, all the input files could be in a folder that I would specify in the program as well as the output folder. I then start the process, come back later and it's finished. I tried googling for a program to do this but I couldn't find one. What program can I use to do this? Free or cheap software would of course be best.
Also, it's a little off topic but while we're on the subject of videos, what happened to the filter button on YouTube? Youtube is where I'll be getting the videos and I'm going to need the filter button so I can search for "creative commons" videos. I'm sure it used to be under the Search bar. Now I can't find it. I tried googling for its location but I couldn't find any helpful info.
"trim" is the precise word here.
To "crop" means to remove a physical area of a video/image (for example to remove black borders), to "trim" is to cut a specific portion of a video (from frame x to frame y)
I don't know how you can do this for many video at once (without creating some kind of custom batch file using ffmpeg, I mean).. since I never had any need for a thing like this. -
Put this in a batch file. Put the batch file in a folder with a bunch of MKV files. Double click on it.
New 1 minute MKV files with the same name will be created in a subfolder called Trimmed. Videos shorter than one minute will be copied (remuxed) to the folder.Code:md Trimmed for %%F in (*.mkv) do ( ffmpeg -t 00:01:00.000 -i "%%~dpnxF" -c copy "%%~dpF\trimmed\%%~nxF" ) pause
I changed your thread title so more people can help you.
Batch trim end of multiple length videos
By Budman1 in forum Video ConversionReplies: 3Last Post: 10th Dec 2019, 07:22 -
Batch trim Videos using FFMPEG (Remove Intro)
By dexterfox44 in forum EditingReplies: 0Last Post: 14th Oct 2019, 14:19 -
By dexterfox44 in forum Newbie / General discussionsReplies: 1Last Post: 14th Oct 2019, 14:11 -
Applications to trim/join videos without losing any quality?
By immortal192 in forum EditingReplies: 9Last Post: 13th Aug 2018, 15:23 -
Is it possible to grab videos off Youtube from a selected trim timeline?
By likwid8 in forum Video Streaming DownloadingReplies: 2Last Post: 17th Jan 2017, 06:08
