i really havent used nero for about a year and a half...... for my vcd's i use adaptec with no problem.... but i made my first cvd and i want to know how to burn a cvd using the newest ver 5.5.8.2
do you mean a VCD?
when you start Nero, you should get the 'new compilation' box. select 'Video CD' from the menu on the left, then click 'new'.
all you have to do then is locate your mpg file(s) in the file browser on the right side of the screen, and drag them across to the left window. Nero should check them to make sure they're VCD compliant.
then, just click 'burn' and that's it!
-Mark -
no.... i do mean cvd
" Chinese video disc is the same as svcd but it uses a different res for better quailty " :P 8) -
Go into nero and hit 'SVCD', then uncheck the standard compliance box. Add your CVD files as normal. This is how I always do it with nero.
Need a coach for anything? Try George Youngs Coaches here for the best service at the lowest prices: http://www.carlberry.co.uk/rfnshowo.asp?O=YOUNG -
walk me thru this..... do i have to switch it to a nero image or will it just burn the mpeg that i created
No, just open Nero, select SVCD and uncheck the "Make Standard Compliant SVCD" button. Drag your CVD file into the "burn" window and after it has checked through it you just burn as normal.
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2014, 11:24 -
Anyone mirrored or saved OGT/CVD subbed test images?
By zinchronized in forum Newbie / General discussionsReplies: 5Last Post: 11th Aug 2010, 22:46 -
Looking for test SVCD images with CVD/OGT subs
By zinchronized in forum Authoring (VCD/SVCD)Replies: 0Last Post: 11th Aug 2010, 07:55 -
Recording audio with Nero Vision 4 Express
By SEE_Studios in forum AudioReplies: 3Last Post: 21st Jan 2008, 15:28 -
Quality loss VHS > CVD, DVD
By rglmrj in forum Video ConversionReplies: 15Last Post: 1st Jun 2007, 12:13
