Hello all, thanks to PM-S, I have been trying out Hybrid, and in particular, QTGMC for deinterlacing my VHS captures. The image is visibly better, even after conversion to MP4.
But, after processing, I have noticed quite pronounced colour banding. After a bit of experimentation, it seems to occur with whatever deinterlacing I use with one exception: the early Muksun filter (15Nov2008 version) in 32-bit VDub. With that Muksun, it doesn't exist. I'm just using the defaults because the Muksun filter is in Russian (I think).
I have replicated this on another tape, different VCR, different capture stick, but haven't resolved what is going on or how to fix it.
It shows up playing in VDub and VLC player.
The Muksun deinterlace is on the left, the Hybrid/QTGMC MP4 on the right.
[Attachment 58796 - Click to enlarge]
Source video linked below.
If anybody could point me in the direction of removing the banding I'd appreciate it.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 9 of 9
The 'color banding' is already in the .avi source. When you inspect the fields you will see that the the even and odd fields shift the bands up/down.
I don't know Muksun, but did you apply same rate or bob (double rate) deinterlacing? Did you capture the tape via composite or S-video?
It is also not recommended to just blindly always use QTGMC with very slow or even placebo settings btw.Last edited by Sharc; 10th May 2021 at 10:38.
Thanks Sharc, I see that now (using Bobdoubler).
Unfortunately, it is baked in to most of my tapes I have of the era. I must have had a bad VCR way back then when I compiled all my tapes.
I don't know Muskun, but did you apply base rate or bob (double rate) deinterlacing?
It is also not recommended to just blindly always use QTGMC with very slow or even placebo settings btw. -
They mostly cancel out if you blend deinterlace, but the "negative" is blend deinterlacing produces blurry results
You can try it yourself, tdeint has a double rate blend mode
Code:AVISource("710USB Kempsey short.avi") assumetff() tdeint(mode=1, type=5, mthreshL=2)
Or you can combine QTGMC for the Y plane, with blend deinterlacing the U,V planes. Some artifacts still remain in top left corner, so ttempsmooth to smooth them over
Code:orig=AVISource("710USB Kempsey short.avi").converttoyv16(interlaced=true) t=orig.assumetff().tdeint(mode=1, type=5, mthreshL=2) q=orig.assumetff().qtgmc() qy=q.converttoy8() tu=t.utoy8() tv=t.vtoy8() CombinePlanes(qy, tu, tv, planes="YUV", source_planes="YYY", sample_clip=q) ConvertToYUY2() TTempSmooth(maxr=1, lthresh=10)
The latter will be noticably sharper, because the Y plane is not blended -
It's a combination of HanoverBars and some noise in the cap. Try this:
Code:AviSource("710USB Kempsey short.avi") AssumeTFF() MergeChroma(last, Blur(0.0,1.0).Sharpen(0.0, 0.7)) QTGMC()
Do you have a link to this old version ? If you double rate deinterlace with the 3.5.6 version the problem is still there . If you single rate deinterlace, you throw away /12 the information, but it doesn't flicker as badly because you're only looking at even or odd fields, but the underlying problem is still there
http://acobw.narod.ru/ -
Thanks very much for your inputs, everyone. Those results are great. Poison, yes, the second of yours looks better. It's fascinating to me that such different approaches lead to similar excellent results.
I will just have to get my head into Avisynth and the big bogeyman QTGMC. I used the derainbow/Bifrost filter in Hybrid with some success, but I can't export any format I want to further edit.
The bullet will just have to be bitten.
Poison, here's the 2008 version of the Muksun deinterlacer:
https://drive.google.com/file/d/1mR0nPJ8CK0axn-GWZVsmgC0X0s78hSBX/view?usp=sharing -
It looks to me like the Muksin deinterlacer does single rate deinterlacing with some kind of field blending (threshold as parameter). The fields blending would explain why the color bands are less visible.
Has it possibly been designed to compensate the PAL Hanover effect in mind, e.g. by repeating the chroma information from each previous line, and blending it with the current line?Last edited by Sharc; 11th May 2021 at 05:06.
Colour issues Help
By OhItsTom in forum Video ConversionReplies: 0Last Post: 15th Jan 2021, 03:22 -
alternating bands of color
By Dan117 in forum Newbie / General discussionsReplies: 4Last Post: 14th Sep 2020, 07:57 -
Help identifying VHS artefact (helical moving vertical bands)
By mp52 in forum RestorationReplies: 15Last Post: 14th Feb 2020, 15:01 -
Colour correction (kind of)
By Marcoh_ in forum RestorationReplies: 7Last Post: 15th Feb 2019, 18:49 -
Colour bleeding when deinterlacing with Yadif
By andy29 in forum Video ConversionReplies: 2Last Post: 9th Jun 2018, 19:34
