My issue with ch. 9 recordings on Windows started about a fortnight ago.
I use (and LOVE) DV-Scheduler with 4 tuners.
Regardless of which tuner I use, instead of one .ts file, I get more than one e.g. a movie may yield seven files.
I can join them all with Video Re Do, but what the heck is happening. Only ch 9 is doing it.
	so strange. i am also having this issue. i was thinking disk issue until i noticed it only seemed to be ch. 9. im in melbourne, if you are too, maybe reception issues?
 whatever it is at least im not crazy.
 please post back if you find anything, as will i.
 (ps, also using dv scheduler, with a hauppauge dual tuner card)
 edit: forgot to mention my .ts files are strangely all nearly 22 mins each, do you see this weirdness also?
	Not happening on my Beyonwiz PVR V2 SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
	I have FOUND AND TESTED A SOLUTION. iN DVScheduler you can go to "System Config" and set "Continue on change in PIDs" to Yes. This will keep the recording to one file.
 This may mean certain media players won't play the file. I don't know if reception dropouts is the cause.
 The first 8 of my files were also nearly 22 mins each too (before the fix). The last was 36 so there's a clue.
	that feature came in version 5.95, and i was running 5.92. have completed the upgrade to 6.05. all settings appear to have stuck, so now onto testing phase.
	I have just discovered that the time splits depend on whether you span only one or e.g. 3 "shows". That may be complicated by whether you have start and end buffers. I use 10 minutes before and 20 after.
	ok, i got a clean 1.9GB 1hr 16 Min file of nine afternoon news. im happy. thanks mate.. ur a legend
 very interesting what 9 are up to tho, sneakily changing the PID every 22mins. trying to annoy people with custom PVR's or something innocent??
  FFMPEG 720P to local Cable TV Channel IssueBy sig1ms in forum ProgrammingReplies: 2Last Post: 27th Feb 2020, 08:56
  Issue with channelBy Cosinus20 in forum Video ConversionReplies: 2Last Post: 4th Jan 2020, 13:26
  Downloading videos from streaming sites (recent change in coding issue)By Anonymous45 in forum Video Streaming DownloadingReplies: 3Last Post: 5th Aug 2019, 13:29
  Windows recent update KB4034664 extended desktop issueBy Ennio in forum ComputerReplies: 2Last Post: 29th Aug 2017, 12:54
  Convert multiple video files to multiple DVD ISOsBy tons of guns in forum Video ConversionReplies: 1Last Post: 14th Jul 2017, 20:52
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
