I was looking for x265 preset option and found this page
i tried to add this following command but ffmpeg gave error, that this syntax is not available for ffmpegCode:https://x265.readthedocs.io/en/master/presets.html
i search on ffmpeg site for the x265 parameters, but could not find any useful. can someone guide me or give me any page link from where i can see the x265 parameters?Code:-limit-tu 4 -no-sao
thank you so much, 10bit encoding working. i will use same output format of input format. i am really new with x265. this is my current x265 encode settings i am trying. kindly let me know if i adding all command good and if need to add something extra or remove extra to make the encode better let me know please.
Code:-vf format=yuv420p10le -x265-params "ref=6:deblock=-3:-3:limit-refs=1:limit-tu=1:tu-inter-depth=4:tu-intra-depth=3:psy-rdoq=1.1:aq-mode=3:subme=5:merange=64:bframes=8:max-merge=5:rc-lookahead=120:lookahead-slices=1:no-sao=1:psy-rd=2.1" -c:a copy -c:s copy
x265 2-pass error using FFmpeg Batch AV Converter
By pascor in forum Video ConversionReplies: 20Last Post: 19th May 2021, 07:40 -
FFMPEG - X265 - Help for correct commands and syntax
By AllThatEvil in forum Video ConversionReplies: 16Last Post: 22nd Mar 2017, 17:04 -
[HEVC] x265 Parameter Reconfiguration
By Italoplk in forum ProgrammingReplies: 1Last Post: 14th Jan 2017, 13:50 -
which time parameter to be considered in video frame for -ss flag in ffmpeg
By db2t4 in forum Newbie / General discussionsReplies: 6Last Post: 26th Oct 2016, 08:14 -
FFMPEG x265 10bit and virtualdub x265 10bit settings
By lilycarolyn in forum Video ConversionReplies: 11Last Post: 6th Jun 2016, 13:44
