Page 2 of 2
FirstFirst 1 2
Results 31 to 39 of 39
  1. Encoding mode: constant quantizer
    AVC Profile: High4:4:4 or None
    enable Lossless
  2. Hello, so rendered the same video twice to remove interlacing. But after the (long) render the file is nowhere. In the notes it says below: So, what am I doing wrong?? Thanks!
    This log is only intended for user information.
    It should not be part of a bug/problem report!!
    Resetting Vapoursynth filter order. Adjust/Rest your FilteringModel defaults.
    Current defaultOutputPath: is empty!
    -> Set it under Config->Path
    Finished startup, finished after 6.788s
    Filtering input files,..
    Analysing 1 input files,...
    Analyzing 'VTS_01_1.mp4'.
    Checking a/v ids with FFMpeg VideoAnalyser,...
    Grabbing audio ids for /Users/pmcarro/Movies/2004 Summer Vacation Outer Banks/VTS_01_1.mp4.
    -> Found the following audio ids: 160
    Analyzing audio streams,...
    Analyzing audio stream with id '160'.
    Analyzing audio stream with MPlayer AudioAnalyser for id '160',...
    Audio analysis problem: found no ffmpegID for audioId (160) and index (0)!
    Grabbing audio data and delay infos,...
    Grabbing video ids,...
    -> Video ids found: 0
    Analyzing video streams...
    Analyzing video stream (0).
    Found no ffmpegID for videoId 0 and index 0.
    starting auto routines for source number: 1
    Detected interlaced Material with 29,../59,.. fps, but didn't detect the material to be telecine. You might want to run 'Filtering->(De-)Interlace/Telecine->Deinterlace/Telecine Settings->Analyse'.
    No input color matrix found, guessing by format and resolution,..
    selecting 'bt709' since input is MPEG-2 and TV scale.
    -> Assuming color matrix to be: bt709
    -> finished auto routines for source number: 1
    Input is completely analysed,...
    Error in audio job creation: Format pcm is not allowed for mp4 output!
    Creating job for current source
    Current input: /Users/pmcarro/Movies/2004 Summer Vacation Outer Banks/VTS_01_1.mp4
    -> Creating jobs for source: (1)
    -> Generating calls for: /Users/pmcarro/Movies/2004 Summer Vacation Outer Banks/V1-deinterlaced.mov
    Enforcing cfr decoder output due to mov output.
    Enforcing ffmpeg remove negative delay due to mov output.
    adding 5 video related calls for source: 1
    createJobs for /Users/pmcarro/Movies/2004 Summer Vacation Outer Banks/V1-deinterlaced.mov
    creating audio subjobs,...
    creating attachment extraction subjobs
    creating video subjobs
    creating muxing subjobs
    optimizing the subJobs
    -> finished creating subjobs for current source
    added new job with id 2023-05-24@09_05_26_4610
    starting 2023-05-24@09_05_26_4610_01_audio@09:05:26.568 - /Users/pmcarro/Movies/2004 Summer Vacation Outer Banks/V1-deinterlaced.mov
    2023-05-24@09_05_26_4610_01_audio finished after 00:00:00.062
    starting 2023-05-24@09_05_26_4610_04_video@09:05:28.260 - /Users/pmcarro/Movies/2004 Summer Vacation Outer Banks/V1-deinterlaced.mov
    2023-05-24@09_05_26_4610_04_video finished after 00:42:53.636
    starting 2023-05-24@09_05_26_4610_05_video@09:48:21.801 - /Users/pmcarro/Movies/2004 Summer Vacation Outer Banks/V1-deinterlaced.mov
    2023-05-24@09_05_26_4610_05_video finished after 00:46:36.199
    delete /private/var/folders/hv/zsghj47n04v1t_hlwd3npcw00000gn/T/V1-deinterlaced_generated_2023-05-24@09_05_26_4610_04.stats
    delete /private/var/folders/hv/zsghj47n04v1t_hlwd3npcw00000gn/T/V1-deinterlaced_generated_2023-05-24@09_05_26_4610_04.analysis
    delete /private/var/folders/hv/zsghj47n04v1t_hlwd3npcw00000gn/T/V1-deinterlaced_generated_2023-05-24@09_05_26_4610_04.stats.cutree
    delete /private/var/folders/hv/zsghj47n04v1t_hlwd3npcw00000gn/T/encodingTempSynthSkript_2023-05-24@09_05_26_4610.vpy
    delete /private/var/folders/hv/zsghj47n04v1t_hlwd3npcw00000gn/T/2023-05-24@09_05_26_4610.d2v
    added new job with id 2023-05-24@10_48_36_4210
    starting 2023-05-24@10_48_36_4210_01_audio@10:48:36.527 - /Users/pmcarro/Movies/2004 Summer Vacation Outer Banks/V1-deinterlaced.mov
    2023-05-24@10_48_36_4210_01_audio finished after 00:00:00.060
    starting 2023-05-24@10_48_36_4210_04_video@10:48:37.500 - /Users/pmcarro/Movies/2004 Summer Vacation Outer Banks/V1-deinterlaced.mov
    2023-05-24@10_48_36_4210_04_video finished after 00:44:07.574
    starting 2023-05-24@10_48_36_4210_05_video@11:32:45.164 - /Users/pmcarro/Movies/2004 Summer Vacation Outer Banks/V1-deinterlaced.mov
    2023-05-24@10_48_36_4210_05_video finished after 00:48:46.165
    delete /private/var/folders/hv/zsghj47n04v1t_hlwd3npcw00000gn/T/V1-deinterlaced_generated_2023-05-24@10_48_36_4210_04.stats
    delete /private/var/folders/hv/zsghj47n04v1t_hlwd3npcw00000gn/T/V1-deinterlaced_generated_2023-05-24@10_48_36_4210_04.analysis
    delete /private/var/folders/hv/zsghj47n04v1t_hlwd3npcw00000gn/T/V1-deinterlaced_generated_2023-05-24@10_48_36_4210_04.stats.cutree
    delete /private/var/folders/hv/zsghj47n04v1t_hlwd3npcw00000gn/T/encodingTempSynthSkript_2023-05-24@10_48_36_4210.vpy
    delete /private/var/folders/hv/zsghj47n04v1t_hlwd3npcw00000gn/T/2023-05-24@10_48_36_4210.d2v
  3. This log is only intended for user information.
    you didn't care to read that
    Only thing one can say from that log is that there is no muxing step in the list of processed stuff.
    -> If you are looking for help:
    a. do not post in a 2 year old post. Better post to https://forum.videohelp.com/threads/345169-Hybrid%28Windows-Linux-Mac%29-Input-x264-x2...5-Xvid-VP8-VP9
    b. read: https://www.selur.de/support and provide a debug output instead of the normal log, posting the normal log, to me is just a way to say that the user probably should not use Hybrid.
    Cu Selur
  4. Sorry, I did not read that! This is the first time I've used this program. I did a search and this is the thread that came up. Also the post before mine was in May of this year. So, I'm not sure why you are being confrontational. Since you are so knowledgeable, why did it go through the render but not leave a file?
    Thanks and sorry for being new to the forum.
  5. Since you are so knowledgeable, why did it go through the render but not leave a file?
    no debug output -> no clue
    Oct 2023
    Poland
    Originally Posted by Barrythecrab View Post
    That's a nice qwik-start.
    Please note: I get choppy stuttery video unless I tick LIBAV video source.
    i know its diggin in a 2 years old thread, but iv got this choppy thing on my export and i really cant find that LIBAV tick
    im working on a AVI from VirtualDUB [capture AVI] in HuffYUV
    my choppy results:
    http://hotmar.media/hi8_kurnik_wyjazd_mala01.mp4
    and when i use VidoCoder with Yadif/Bwdif BOB i got nice smooth video, but only when i tick interlace detection to OFF, else i got choppy results like from Hybrid
  7. You had the field order backward. Use AssumeTFF() or AssumeBFF() before deinterlacing. Video of your sample with the frames re-ordered attached.
    Oct 2023
    Poland
    thanks a LOT! if someone has a similair problem, ticking this option in HYBRID will do the trick.
  9. Tried HYBRID out for the first time today to aid with a deinterlacing situation I've got.
    It seemed to do a good job with the settings recommended here, but the bitrate was very low in the final file so I'm re-running with a VBR bitrate target of 6Mbps (standard-def source footage).
    I noticed after the initial run that the blocks were very noticable in the black areas of the image that lacked detail and they jumped around quite a bit. Hoping it was just a bitrate issue, otherwise I have to figure out what settings to tweak to avoid that. Pre-emptively posting here to see if anyone has a recommendation on that (if it wasn't just low bitrate)
    (I did play the source .MOV files and didn't see those artifacts)
