    May 2005
    PAL User
    Hello all, I have come across an MPEG from years ago I converted from DV-AVI. I obviously didn't check it afterward because I just tried to play it in VDub and got a message "does not have a video stream". VideoRedo throws a similar message and Mediainfo shows it has nothing in it.
    If anybody could assist with advising how to fix this file (I have a couple of others doing the same thing) I would be grateful.
  2. Why are you posting the path to the file on your computer? Nobody can access that. You need to upload it to some file transfer service.
    May 2005
    PAL User
    Thanks Jabago, I clicked on "insert video" (next to "Upload image") because I thought (obviously erroneously! smack smack) that it might insert my video. Why is that there?
    Now attached.
  4. You can't "repair" "flap_test.mpg" - it's all zeros in a hex editor
    May 2005
    PAL User
    OK, thanks Poison. "Fix" was obviously not a good choice of word on my part!
  6. Yes, it's all zeros. It's as if you perfectly erased all the text in a book. It's all blank pages. There's no hint of what was there before.
    May 2005
    PAL User
    Thanks Jagabo.
