  1. Hello, I just bought a fairly obscure show that I absolutely love on blu-ray as a company just localized it here, It was originally in 4:3 aspect ratio and I'm a bit of a crt purist, I think basically all 4:3 content looks far better on my crt (the show is 480p) however as it's a blu-ray it seems to actually be in 16:9 aspect ratio with black bars coded in or something so attempting to play it on my crt puts it into a windowbox with black bars on all sides. Is there any way in the world to fix this? As this is the only release the show will get here, I will go so far as to edit the actual files on the disc if that's possible. Edit: Is there any blu-ray player that has a zoom function or something similar? The crt is a little too old to have one but I think that could fix the problem as well.
  2. You must crop the vertical bars and recode with 4:3 aspect ratio. This way you'll get a full screen picture on you crt. If you post a mediainfo report of your mivie here we can help you further.
  3. Originally Posted by ProWo View Post
    So the disc actually can be altered?
    canada
    Nope,you will need to extract the video and re-encode it.
  5. Originally Posted by johns0 View Post
    If I were to buy a blu-ray player with a zoom feature would I lose some quality by using it? Theoretically it should fill the screen perfectly since the aspect ratio is still 4:3 just smaller.
