I have a problem with loading AVI's into MediaStudio Pro 6.0, after capturing them with VDub I find I cannot load them into MSP6.
Run them through "save as old AVI" and it will open up and let me edit them. I have the same problem when I download large (movie 150Mb+) AVI files from the net.
I went into uleads' web site and it said to remove any DV codex from my system. The only codec that refers to DV is my pinnacle DC10+ one, and I've had this problem before I installed this device.
Just to clarify what Iam trying to do is: capture VHS in an uncommpressed AVI in Virtual DUB (which me thinks is doing right , i dunno for sure but) then edit it in MSP6.0 and using it last for converting to a Mpeg2 480x480 @ 4000 bitrate to burn to an SVCD.
(the settings come from Maverik's post on "How do I get rid of those STINKIN' BLOCK's in the XSVCD's!!")
Probably a simple stuff up on my part, but when you look at a puter screen for 2 days and read pages of info, well you know what tends to happen to your brain LOL
tha's funny , i get the same problem i guess that's why i drink so much coffe , and i been constantly late to work,but anyway i have gooten the wors result using media studio, couldnt load up the avi, system crashes and more, and also the results avi to mpg was pretty bad , audio was alway out of sync....
Mavrick here...
Are you running the latest copy of VDUB?
what is your e-mail address? I'm putting a very simple step-by-step guide on how I got it to work. Hopefully, others wont have to spend 3 weeks like I did to make their first high quality XSVCD...
VDub wont load *.VCF files in command line mode.
By zzyzx2 in forum Video ConversionReplies: 11Last Post: 15th Sep 2011, 07:48 -
virtual dub wont load the full vob
By tvlreject in forum EditingReplies: 19Last Post: 28th Mar 2008, 21:13 -
HDTV2DVD - .TS wont load
By NotSoEasy in forum SVCD2DVD & VOB2MPGReplies: 11Last Post: 15th Mar 2008, 20:09 -
dvr-ms at 59.94fps wont load
By dalego in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 7th Oct 2007, 18:38 -
xvid wont load in program
By dvdhouse111 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 6th Jul 2007, 05:26
