Hello, I'm very new in this forum, I ve been searching lot of information to finally transfer my tapes, I need make some few questions, I know here are too many topic about this but I have been able to fix my problems!
Well I'm trying to transfer tons of VHS tapes PAL and SECAM, I have an Intensity shuttle and I use a ES10 as pass, well in some tapes I have audio sync problems and I cant fix them, I have tried VirtualDub, OBS, AmaRec, this last one is the best working one, but I still get some audio sync problems or sometimes the footage frezen for couple seconds or a skip, I use also a audio card tascam so I capture the audio by this device (I have tried also with intensity shuttle but its worse low speed audio and video speed fine) I have a Ryzen 7 3750H, 8 RAM and 500GB hd that is a nvme, I have free like 200GB, maybe that is the problem? I'm purchasing a Diamond video card, I hope it works fine.
thank you all for the help!
If you are using Win 10 disable all the background activities , although it's hard to do, that's why Win 7 and AmerectTV are preferred.
The wifi in itself is not an issue, the processes are, You have to understand that Window 10 is designed based on the 21st century usage and needs, Microsoft doesn't care about capturing analog tapes.
It still doesnt work, when I capture with virtual dub the video is out of sync, the audio is going first for at least 1 second in every capture, I have tried a lot timing options and is always the same or worse
With the ES-10, are you passing the audio through as well? The ES-10 and ES-15 have a small processing delay. So, if the audio is not also passed through the ES-10, the video will be out-of-sync.
intensity shuttle needs update PROBLEM
By Matm Algharbi in forum Capturing and VCRReplies: 1Last Post: 25th May 2020, 04:56 -
BM Intensity Shuttle Owners Feedback Needed
By dellsam34 in forum Capturing and VCRReplies: 18Last Post: 26th May 2019, 15:31 -
Intensity Shuttle Problem.
By Bob Loblaw in forum Capturing and VCRReplies: 489Last Post: 3rd Sep 2018, 02:35 -
Blackmagic Intensity Shuttle usb3.0 SD-mode only captures @59.97fps?
By clashradio in forum Capturing and VCRReplies: 19Last Post: 31st Jan 2018, 22:45 -
VirtualDub Won't Recognise Intensity Shuttle
By koberulz in forum Capturing and VCRReplies: 8Last Post: 2nd Aug 2017, 02:58
